james Posted September 18, 2012 Author Share Posted September 18, 2012 Out with the old Gaps checked and some copper greeas on the threads ........ (CAUSE OCD )And in with the new ( when seated 2/3 a turn is tight enough )Not the best fit but they are not oe Its so nice to be able to finaly give full open throttle at low rpm with out To Do List:[*:28qa03pe]Fuel Filter[*:28qa03pe]Gear Shift Upper & Lower Boots[*:28qa03pe]Clean Throttle Body[*:28qa03pe]Sort Out More Lumbar Support [*:28qa03pe]Get Exhaust Leak Fixed[*:28qa03pe]Front Brake Pads [*:28qa03pe]Polish & Wax[*:28qa03pe]Valve cover gasketI think i will tackle the throttle Body next i will have to remove the inlet manifold and throttle body to do a full job on it Quote Link to comment Share on other sites More sharing options...
james Posted September 18, 2012 Author Share Posted September 18, 2012 Thanks Tom Quote Link to comment Share on other sites More sharing options...
Krzys Posted September 20, 2012 Share Posted September 20, 2012 She's coming along dude! Sometimes the best enhancements can come from a good clean! Quote Link to comment Share on other sites More sharing options...
james Posted September 20, 2012 Author Share Posted September 20, 2012 For me the best mod is having a well serviced car & thanks Quote Link to comment Share on other sites More sharing options...
james Posted September 22, 2012 Author Share Posted September 22, 2012 More maintenance work todayFirst off was the throttle body/intake mainfold, my revs ware dipping every so often so it needed a good clean I used egr as i could'nt find throttle body cleaner only carb cleaner was available and that has a chemical called acetone which on the mx5's throttle body would strip the none stick coating off which would lead to poor idlingPritty dirtyMuch betterNext was the headlight earth points, so out they comeNot even metal to metal And the passingers sideTo help stop rust setting in again a good coat of satin black (where is edd china )And finaly, the mx5 has not cabin filter so all the dust and everything get blown through the fan and into the car and i thought i heard leaves swerling around inside the fan so i took it out to have a l@@kHow right i was (I broke a clip)Happy out now even gave her a good power hose after a blast on the b roads yesterday with the roof off To Do List:Fuel FilterGear Shift Upper & Lower BootsSort Out More Lumbar SupportGet Exhaust Leak FixedFront Brake PadsPolish & WaxValve cover gasketNext Is The Fix The Leaking Exhaust And Fit A New Fuel Filter Quote Link to comment Share on other sites More sharing options...
james Posted September 22, 2012 Author Share Posted September 22, 2012 I think so haven't used them enough yet Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted September 23, 2012 Share Posted September 23, 2012 Good job on the TB mate, get the fuel filter and exhaust sorted and she'll be running like new. Quote Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted September 23, 2012 Share Posted September 23, 2012 I love the fact you make the time to keep it all serviced.I have been meaning to clean my TB, do they get very dirty on the B18's? Quote Link to comment Share on other sites More sharing options...
james Posted September 23, 2012 Author Share Posted September 23, 2012 Yep it gets quite gunky in there all right, i had intermittent idle problems so taking off the throttle body and cleaning it was a must =]some time i am going to take off the intake manifold and get a brush in there and do a proper job (like cleaning a chimney) Thanks nick, she will be close but no cupa just yet =] Quote Link to comment Share on other sites More sharing options...
Guest Posted September 23, 2012 Share Posted September 23, 2012 your MX5 is looking sharp mate i agree with the well serviced comment makes hell of a difference to any car well done James. Quote Link to comment Share on other sites More sharing options...
