Mazda Mx5
james
Out with the old
Gaps checked and some copper greeas on the threads ........ (CAUSE OCD crazy.gif1 )
And in with the new ( when seated 2/3 a turn is tight enough )
Not the best fit but they are not oe
Its so nice to be able to finaly give full open throttle at low rpm with out ecstatic.gif1
To Do List:
    [*:28qa03pe]Fuel Filter
    [*:28qa03pe]Gear Shift Upper & Lower Boots
    [*:28qa03pe]Clean Throttle Body
    [*:28qa03pe]Sort Out More Lumbar Support
    [*:28qa03pe]Get Exhaust Leak Fixed
    [*:28qa03pe]Front Brake Pads
    [*:28qa03pe]Polish & Wax
    [*:28qa03pe]Valve cover gasket
I think i will tackle the throttle Body next i will have to remove the inlet manifold and throttle body to do a full job on it :ugeek:
More maintenance work today
First off was the throttle body/intake mainfold, my revs ware dipping every so often so it needed a good clean :)
I used egr as i could'nt find throttle body cleaner only carb cleaner was available and that has a chemical called acetone which on the mx5's throttle body would strip the none stick coating off which would lead to poor idling
Pritty dirty
Much better
Next was the headlight earth points, so out they come
DSC00286_zps3c4c7391.jpg8-)
Not even metal to metal :evil:
And the passingers side
To help stop rust setting in again a good coat of satin black (where is edd china :lol: )
And finaly, the mx5 has not cabin filter :roll: so all the dust and everything get blown through the fan and into the car and i thought i heard leaves swerling around inside the fan so i took it out to have a l@@k
How right i was :D (I broke a clip)
Happy out now even gave her a good power hose after a blast on the b roads yesterday with the roof off WACK11111
To Do List:
Fuel Filter
Front Brake Pads
Polish & Wax
Valve cover gasket
Next Is The Fix The Leaking Exhaust And Fit A New Fuel Filter
Yep it gets quite gunky in there all right, i had intermittent idle problems so taking off the throttle body and cleaning it was a must =]
some time i am going to take off the intake manifold and get a brush in there and do a proper job (like cleaning a chimney)
Thanks nick, she will be close but no cupa just yet =]
