Mr Brown Posted January 18, 2014 Author Share Posted January 18, 2014 was thinking that it would be on the same circuit as the lighting ring only with a seperate fuse obviously Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted January 18, 2014 Share Posted January 18, 2014 Surely then the stereo would come on with the lights which come on without ignition. The illumination comes on with the stereo, however mine dims when you switch the lights on so not sure how that works. Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted January 18, 2014 Author Share Posted January 18, 2014 Surely then the stereo would come on with the lights which come on without ignition. The illumination comes on with the stereo, however mine dims when you switch the lights on so not sure how that works.Thats exactly what use to happen untill the other day (put main beam on with no ignition stereo would start) Also turn lights on with no ignition and lighter used to power up but does not now either Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted January 18, 2014 Share Posted January 18, 2014 Thats exactly what use to happen untill the other day (put main beam on with no ignition stereo would start) Also turn lights on with no ignition and lighter used to power up but does not now either Hmm, definitely something not right in there. Is it using an ISO connector? Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted January 18, 2014 Author Share Posted January 18, 2014 im sure it has but i forget as it was nearly two years ago since i put my stereo in. I will remove stereo to check and find out just wanted to throw some confusment out there for everybody. We love a puzzle, see who gets the correct diagnosis Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted January 18, 2014 Author Share Posted January 18, 2014 Just been reading the diagram and the lighter has a wire no 19 with a 10amp fuse for the illumination (bulb blown anyway) and the stereo also has the no19 wire going to a 10amp fuse also i suspect my prediction is going to be correct and that 10amp fuse has popped.. Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 18, 2014 Share Posted January 18, 2014 I'd say it has reverted to how it was originally if a fuse has gone. Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted January 18, 2014 Author Share Posted January 18, 2014 there will be one wire wrong behind the stereo causing what was happening Quote Link to comment Share on other sites More sharing options...
DAVEMB2 Posted January 18, 2014 Share Posted January 18, 2014 Odd wiring can be a pain I stil have to find out why the heater blower on trinityD is not working and it's not the Rez pack lol Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted January 18, 2014 Share Posted January 18, 2014 I'd say the live has been bypassed so the stereo works without ignition. Quote Link to comment Share on other sites More sharing options...
