DeLaSoul Posted February 11, 2013 Share Posted February 11, 2013 I fitted my Energy Suspension bush kit to my MC2 over a year ago and have had no issues. The only bushes it doesn't come with are the rear trailing arm and the rear toe links so I went Mugen arms and found aftermarket ones for the links from Hond-R. I believe Energy do make a set for the trailing arms though. Just make sure to use plenty of grease to stop it squeaking and get the alignment checked once your finished. Instructions were rubbish but they weren't hard to do.HTH Quote Link to comment Share on other sites More sharing options...
marko Posted February 11, 2013 Share Posted February 11, 2013 you got a link to the kit you bought? also links to the other parts would be a plus Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted February 12, 2013 Share Posted February 12, 2013 I would call the relevant people to make sure these fit but I believe these were the ones I bought were:Trailing arm bush - http://www.vtecdirect.com/online/cgi-bi ... 5-XE9-S0N0Energy suspension bush kit - http://www.tegiwaimports.com/energy-sus ... 6-00-3215/I can't find the link to the toe compesator bushes I used but there are plenty on eBay, just need ones for an EG/DC2. Quote Link to comment Share on other sites More sharing options...
Nav Posted August 28, 2013 Share Posted August 28, 2013 Will the below one work for the mb6.??? Option: 1996 - 2000 Honda Civic VTihttp://www.h-tune.co.uk/suspension/bushes/energy-suspension-hyperflex-master-kits.html Quote Link to comment Share on other sites More sharing options...
noodels Posted August 28, 2013 Share Posted August 28, 2013 maybe an egtalk to scott about it at Htune be best.just put gear linkage ones on feels much better got hardrace top camber ones coming soon<metalastic type my preferance> Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted August 29, 2013 Share Posted August 29, 2013 Defo need an eg 92-95 set. Arb bushes wont fit tho..Ihave energy trailing arm bushes in now. All well and good but I'm positive they make the car unstable under hard braking. Back end slides all over the shop when slamming the anchors on! Quote Link to comment Share on other sites More sharing options...
Nav Posted August 29, 2013 Share Posted August 29, 2013 cool EG it is then.. cheaper than the EK .. I read somewhere that the DC2 kit fit as well... dont ask me where i read it... been scrounging the web for info on a set of polys for MB6. now to source a hydraulic press... hmm... gatta keep looking..anyone wanna lend a hydraulic press for a week.. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted August 29, 2013 Share Posted August 29, 2013 You shouldn't need a press. Take a blow lamp to old bushes then the metal part will knock out with a few good hits. Energy ones just push in by hand. Easy peasy Quote Link to comment Share on other sites More sharing options...
Nav Posted August 30, 2013 Share Posted August 30, 2013 got it.. blow lamp... and press... Quote Link to comment Share on other sites More sharing options...
Guest colinjuk Posted January 26, 2014 Share Posted January 26, 2014 Hey all, i got the EG energy kit for my mb6, the front new bushes went in well, but the back lower control arms bushes are to small with out the metal sleeve, the instructions said to remove them now a bit lost I need 35mm outer sleve with a 31mm inner any one know where to get them from, and need LCA bolts thanks Quote Link to comment Share on other sites More sharing options...
