civicturbo79 Posted November 26, 2009 Share Posted November 26, 2009 I do not use the car in the week . so you may see me out and about at the weekends. I would have a look around the manifold were it bolts to the head and around an joins for black areas , or just have it running and use your fingers to feel around the joins ( but do not but you finders on the exhaust ) or you will loose your finger prints. Rich. Link to comment Share on other sites More sharing options...
tontvti Posted November 26, 2009 Share Posted November 26, 2009 My manifold gasket has been split for a while, everyone says it sounds like a tractor when I accelerate low down in the revs. Also when I put the heating on in the car you can smell exhaust fumes.You can kinda see some of the black patches where it has split in the below picturehttp://i980.photobucket.com/albums/ae28 ... 1258807689I'm waiting on an impact wrench to be delivered so I can change it, the nuts are on too damn tight.(The other half of the airbox is going to when the impact wrench comes, rusy bolts )Tony Link to comment Share on other sites More sharing options...
KiNK43 Posted November 27, 2009 Author Share Posted November 27, 2009 ok so its just a case of feeling round for flow ok... im makin a day of it sunday.its my birth day and no one is gonna interupt me! hagonna have a pop at the tappets my self too see how it goes.thanks for all the input . much appreciated Link to comment Share on other sites More sharing options...
slosei Posted December 3, 2009 Share Posted December 3, 2009 if its not the valve clearances it may be the LMAs Link to comment Share on other sites More sharing options...
KiNK43 Posted December 3, 2009 Author Share Posted December 3, 2009 just had so little time. not even checked it out yet. kids been ill so no time.weekend again. will do valve clearences. did manage to go out and get a feeler guage so half way there.please enlighten me what are LMA's? thanks Link to comment Share on other sites More sharing options...
slosei Posted December 4, 2009 Share Posted December 4, 2009 there are the things that hold up the rocker for the high cam lobe when car if off vtec, when you look at the rockers there found underneath the middle rocker, iirc there £90 for a set from honda Link to comment Share on other sites More sharing options...
jalesi2001 Posted December 4, 2009 Share Posted December 4, 2009 there are the things that hold up the rocker for the high cam lobe when car if off vtec, when you look at the rockers there found underneath the middle rocker, iirc there £90 for a set from hondaWow, never ever heard of those being replaced, the whole set-up in the head is so ultra reliable!! Have you had to change yours then bud?? Link to comment Share on other sites More sharing options...
civicturbo79 Posted December 4, 2009 Share Posted December 4, 2009 Im the same i have never needed to change them on a b18c4 , i have heard them a bit noisey on a b16a with 170,000 on it . it will not be them i would be willing to put money on it . Rich. Link to comment Share on other sites More sharing options...
supermike Posted December 5, 2009 Share Posted December 5, 2009 what are TAPPETS??lolTappets is another name for Valve Clearances. Its the gap between the rocker arm and the valve in your head. They have to be set to certain measurements, too lose and you loose performance and get a rattle type noise from the top of your engine, too tight and you can loose compression, and ultimately burn out your valves. (Very rare on a honda though in my experience!!!)Burnt out my valves because the clearences had become too tight! Wasnt a good day. Link to comment Share on other sites More sharing options...
KiNK43 Posted December 5, 2009 Author Share Posted December 5, 2009 right then. as well as a few other bits n bobs. tried to do tappets today.... think i bit off a bit more than i could chew.once i had the rocker cover off everything looked familiar, all set to go. then probably the stupidest thing ever. i coulndt turn the timing sprockets to tdc. or at all for that matter.tried to reach down to the crank but couldnt get enough leverage to turn from there as space is minimal.then things went real bad... previous owner has obviously sprayed rocker cover whilst still on engine so every joint that broke threw shards of red paint into the head. took the best part of an hour picking all the paint out. touch wood running ok now but could have been catastrophic. so next question is how do i turn the crank? Link to comment Share on other sites More sharing options...
