no vtec in mc2 HELP
kyekye09
  • Replies 26
Top Posters In This Topic
:idea: >>>>>>>>ive got a faulty tps <<<<<<<<<<< :idea:
How would I tell if I have this problem?
I've checked the link to check the IAB's are working by watching the diaphragm lever with the ignition off and again with the ignition on but nothing happens!?
Could I not have any VTEC or IABS working? No wonder it feels like I'm driving with handbrake on!!!
Any ideas please? or do I need garage diagnostics?
if your tps is faulty your engine light will be on as for checking the iab's itook the vac pipe of and sucked and sucked and yes i sucked some more.... you will hear the diaphragm flex inside i then reconnected it up... tb i bought complete will tps and map sensor so i didnt do any of the above checks (ie volt meter test/set) but im still idling at 2k on start up and only dropping to 14ish.k on warn
you probs wont see alot of movement from the switch i done mine by feel or get a chalk pen to mark it when off and on.....
sorry if this is no help but im new to this b18 witch craft...!!!!
might be worth reconecting collant bypass mod,
asess tick over,and reset ecu. :?
And clean the TB looks very dirty :idea:
check cranshaft breather also maybe blocked with all that oil about,also check for colapsed pipes ect.
or ask that snail his name is brian :lol:
