james Posted June 27, 2013 Share Posted June 27, 2013 consider this, if the water pump fails after the timing belt install you will need to redo your work again + more .... make sure the water pump is not making noise basically Quote Link to comment Share on other sites More sharing options...
simpo Posted June 27, 2013 Share Posted June 27, 2013 Just get a water pump I went to do mine the other week got to the point of taking the belt off and seen pump was leaking so had to put it all back together as couldn't get a pump Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted June 27, 2013 Share Posted June 27, 2013 On 6/27/2013 at 2:24 PM, simpo said: Just get a water pump I went to do mine the other week got to the point of taking the belt off and seen pump was leaking so had to put it all back together as couldn't get a pump x2, it's worth doing, even though the water pump is not a serviceable part it is worth changing as when I had my cambelt changed we discovered the pump was weeping so it all had to come off again to change the pump a couple of weeks later. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted June 27, 2013 Share Posted June 27, 2013 Defo do water pump and tensioner. For what they cost just do them. Sounds like a common problem leaky water pump. Mine was leaking too when I did my cambelt Quote Link to comment Share on other sites More sharing options...
matty1 Posted June 27, 2013 Author Share Posted June 27, 2013 Yea, got water pump, tensioner, cambelt, and new rocker cover seal. With all the other belts to. And a newly sprayed rocker cover to that I bought at japfest. I'm ready!!! YEA!!! Quote Link to comment Share on other sites More sharing options...
james Posted June 27, 2013 Share Posted June 27, 2013 everyone must know that the coolant system should never need topping up, if it dose you have a leak Quote Link to comment Share on other sites More sharing options...
matty1 Posted June 29, 2013 Author Share Posted June 29, 2013 Stripped everything out only to find that they supplied me with the wrong timing belt kit!!! Should be here today though about 12.30. So annoying! Quote Link to comment Share on other sites More sharing options...
james Posted June 29, 2013 Share Posted June 29, 2013 OUCH!!! bad luck Quote Link to comment Share on other sites More sharing options...
simpo Posted June 29, 2013 Share Posted June 29, 2013 FFS sh1t when that happens . Hopefully u will get one at12.30 Quote Link to comment Share on other sites More sharing options...
