vtec2011 Posted July 21, 2013 Share Posted July 21, 2013 To those who don't know, last year or late 2011 I have put another gearbox in my MB3 which is from a 2000 1.6 Civic Coupe. The code casted on the gearbox is B000 P9A. Just recently I had trouble getting it into 2nd and 3rd gear. It only does this when I'm gearing down. It does it when driving it easy or hard. I can be driving in 4th and when I want to slow down and go into 3rd, it's nearly impossible! It doesn't crunch or grind, it just simply won't go into gear! It's got Honda MTF oil in and I have checked the levels. One thing I didn't do is change the clutch when I fit the 1.6 gearbox. Could it be a weak clutch or maybe clutch fluid? Thanks for reading and thanks in advance Quote Link to comment Share on other sites More sharing options...
simpo Posted July 22, 2013 Share Posted July 22, 2013 Maybe clutch have u tried bleeding it first? Also maybe a leaky clutch slave cylinder? Quote Link to comment Share on other sites More sharing options...
Paulvti Posted July 23, 2013 Share Posted July 23, 2013 Before digging into the depths try the shallows,Gear linkage, hydro slave cylinder, fluid levelUsually with a clutch it would be all gears, up and down, juddering on pull off or slipping... Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted July 24, 2013 Author Share Posted July 24, 2013 Thanks lads! I cannot see any leaks, I even had it up on the ramps to check. I checked the slave cylinder, looks fine. Gear linkage seem to have a lot of play so I re adjusted it and tightened it up. No difference so far... I will bleed the clutch soon and might just go for a new clutch anyway. It wasn't looking great when I seen it last year. Thanks again Quote Link to comment Share on other sites More sharing options...
Paulvti Posted July 25, 2013 Share Posted July 25, 2013 I can't believe you didn't change the clutch while the gearbox was off!? School boy error Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted July 27, 2013 Author Share Posted July 27, 2013 I didn't have money for a clutch at the time and that was nearly 2 years ago I think. So the clutch is doing pretty well Quote Link to comment Share on other sites More sharing options...
simpo Posted July 27, 2013 Share Posted July 27, 2013 Did u pull the rubber back on the slave cylinder ? Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted July 27, 2013 Author Share Posted July 27, 2013 Yeah I already checked the slave cylinder. Looks very rusty but I will try bleed the clutch first, then the slave cylinder Quote Link to comment Share on other sites More sharing options...
Paulvti Posted July 27, 2013 Share Posted July 27, 2013 I didn't have money for a clutch at the time and that was nearly 2 years ago I think. So the clutch is doing pretty well Quote Link to comment Share on other sites More sharing options...
simpo Posted July 28, 2013 Share Posted July 28, 2013 Yeah I already checked the slave cylinder. Looks very rusty but I will try bleed the clutch first, then the slave cylinderPretty sure the bleed nipple is on the cylinder may want mould grips as normally pretty rusty. I had 2 probs with my gearbox one was poping out of 5th and second was struggling to go into gear. One was low gearbox oil and second was it needed bleeding Quote Link to comment Share on other sites More sharing options...
