Camber setup for track days
Dexter
I'm taking my car in for an alignment. Any suggestions how much camber would be optimal for track days? It's a 1.8 deck, sitting pretty low on H&R coils and has a Blox camber kit in the front. A bit of negative is in order but how much? :???:
  • Replies 20
Top Posters In This Topic
for a type R
Standard Alignment data -
these settings are in degrees (minutes of)
96 jdm
front toe +0 (max tolerance -7 to +7)
front camber -30 ( max +30 to -1.30)
rear toe +5 (max +0 to +7)
rear camber -45 (max +30 to -1.30)
98 ukdm
front toe +0 (max -9 to +9)
front camber -30 (max +30 to -1.30)
rear toe +9 (max +5 to +18 )
rear camber -45 (max +0 to -2.00)
98 jdm
TBC ?
Alternative Settings
Whiteline suggest:-
Touring
front toe 0.00
front camber -1.00
front caster +5.5 (excessive, 3 to 4 may be enough)
rear toe 1.0 out
rear camber -1.00
rear caster n/a
Sport
front toe 0.00
front camber -1.75
rear toe 2.0 out
rear camber -1.50
for a type R
these settings are in degrees (minutes of)96 jdm
rear camber -45 (max +30 to -1.30)98 ukdm
rear camber -45 (max +0 to -2.00)98 jdm
TBC ?Alternative Settings
Whiteline suggest:-Touring
front toe 0.00
front camber -1.00
rear toe 1.0 out
rear camber -1.00
rear caster n/aSport
front toe 0.00
front camber -1.75
rear toe 2.0 out
rear camber -1.50
is that same as a mb6??
Thanks, noodels. I think the whiteline sports is closest to the settings i'm looking for.
is that same for a mb6
Here's the standard specs for mb6/mc2 (taken from Haynes):
Front:
Camber angle: -0,007' to 1
Castor: 1,10' to 1
Toe-in: 0.0 to 2.0 mm
Rear:
Camber: -0,50' to 0,45'
Toe-in: 2.3 to 2.0 mm
camber will depend upon grip/tyres, spring rates etc.
the mb6 is prob more like the MGZS than integra for setup, although essentially they share many components, but wheelbase is likely different, as are arb's (certainly the rear), different castor as MG swapped upper arms, but so can you.
post up the tyres, spring rates etc and I may be able to give you a clue on geo.
Okay i got the alignment done a few days ago and this is what i got:
Front camber -2,36 / -2,36
Front caster 1,30 / 1,48
Front Toe-in -0,06 / - 0,06
Rear camber -2,48 / -2,36
Rear toe-in 0.00 / -0,03
I would've gone for less rear camber but the car sits so low it wasn't adjustable any more, so i guess I'll need a rear camber kit in the future. Otherwise i'm very satisfied with the results. I visited the track afterwards and my lap time improved from 1:44,84 to 1:40,95! And that's all just by adjusting camber and toe. It goes like a train now. Thanks to Zuissi for his insight on this.
The mechanic did warn me about excessive tire wear with such an aggressive camber setup, but i insisted, because race car :grin:.
