Honda Paul Posted September 1, 2013 Share Posted September 1, 2013 Wow, that's alot of camber! I was advised not to go much past 1.5 if I wanted the tyres to atleast last further than my house to the petrol station lol. Sky's the limit If u can afford to keep changing tyres. Well done! Quote Link to comment Share on other sites More sharing options...
Dexter Posted September 2, 2013 Author Share Posted September 2, 2013 4secs =good progress Wow, that's alot of camber! I was advised not to go much past 1.5 if I wanted the tyres to atleast last further than my house to the petrol station lol. Sky's the limit If u can afford to keep changing tyres. Well done! Thanks, yes i reckon 4 secs is quite allright . I only drive about 1 tank of gas per month + the occasional track day so i think it's not too bad for the miles i accumulate. Quote Link to comment Share on other sites More sharing options...
jasons Posted September 3, 2013 Share Posted September 3, 2013 Personally, I would have less camber on the rear than the front. What is the ride height? Or is it dropped to the floor? Quote Link to comment Share on other sites More sharing options...
93 Accord Posted September 6, 2013 Share Posted September 6, 2013 -2.3 camber for the track isnt alot at all. It does depend on how much roll you have, if you have a softer setup you will roll over the tyre more, and thus need more camber. But thats a very camber dynamic way, really you should have a stiffer setup so the values dont change much under cornering. With my Accord for instance, the setup is for track, i run -2.5 all round and i consider that small enough not to change that for the road, and hence that what i daily on. I have no tyre wear issues because my toe is spot on and my bushes are good. Toe for track should be toe out at the rear, -2mm say, and -1mm at the front, for maximum steering response, but thats a bit twitchy for the road, 0 all round is best for tyres obviously. bit of toe in at the rear for stability. Quote Link to comment Share on other sites More sharing options...
Dexter Posted September 7, 2013 Author Share Posted September 7, 2013 Personally, I would have less camber on the rear than the front. What is the ride height? Or is it dropped to the floor? For track it's pretty low, almost as much as the H&R coils will go. Here's a pic with my street setup, for track i raise the front 10mm to get it stiffer since there's no damping adjustment. Quote Link to comment Share on other sites More sharing options...
jasons Posted September 9, 2013 Share Posted September 9, 2013 it will handle better and roll less if you raise it. That is very low. Quote Link to comment Share on other sites More sharing options...
Honda Paul Posted September 9, 2013 Share Posted September 9, 2013 it will handle better and roll less if you raise it. That is very low.X2 Quote Link to comment Share on other sites More sharing options...
Dexter Posted September 10, 2013 Author Share Posted September 10, 2013 it will handle better and roll less if you raise it. That is very low. I think it's still pretty high! But like i said i raise it a bit for the track, and the camber/toe is set for the current height so for now it'll do. But you're probably right! Quote Link to comment Share on other sites More sharing options...
jasons Posted September 14, 2013 Share Posted September 14, 2013 if you understand roll centres, you'll know I'm definitely right! Quote Link to comment Share on other sites More sharing options...
Dexter Posted September 16, 2013 Author Share Posted September 16, 2013 if you understand roll centres, you'll know I'm definitely right! I'm sorry but i don't, i looked it up from wiki but that's just too much theory instead of practice for me. From what i've noticed observing other cars at the track, almost all of them are very low (or just low, in my book ), especially the plateless honda's and beemers people build as cheap track cars. My logic says low = less roll, the only reason i raise my car for track is because my coils lack damping adjustment. But you seem to know what you're talking about, what kind of setup you use for trackdays? Quote Link to comment Share on other sites More sharing options...
