carl747 Posted October 17, 2013 Author Share Posted October 17, 2013 So turns out its not sorted Thinking of changing everything now water pump / radiator / cts Seems to have lost water from the tank but can't see any leaks anywhere Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted October 17, 2013 Share Posted October 17, 2013 Booger, that's annoying. Quote Link to comment Share on other sites More sharing options...
crazyrob9999 Posted October 17, 2013 Share Posted October 17, 2013 Did you check to seeing the whole of the radiator hot? Quote Link to comment Share on other sites More sharing options...
carl747 Posted October 17, 2013 Author Share Posted October 17, 2013 Did you check to seeing the whole of the radiator hot?Yeah radiator was hot Quote Link to comment Share on other sites More sharing options...
noodels Posted October 18, 2013 Share Posted October 18, 2013 does it smell of coolant in the car Quote Link to comment Share on other sites More sharing options...
carl747 Posted October 18, 2013 Author Share Posted October 18, 2013 does it smell of coolant in the car No Quote Link to comment Share on other sites More sharing options...
crazyrob9999 Posted October 18, 2013 Share Posted October 18, 2013 From cambelt area is there red or white powdery stuff around it? Quote Link to comment Share on other sites More sharing options...
Roylewaa Posted October 18, 2013 Share Posted October 18, 2013 How much did the level of coolant drop?Could have possibly been an airlock which has bled itself of, hence the level dropping? Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted October 18, 2013 Share Posted October 18, 2013 As above if ya site its loosing coolant pull carpet back see if coolant leaking inside from Matrix. And quite often water pump leaks. Check for wet or dried powder around crank pulley area. Quote Link to comment Share on other sites More sharing options...
carl747 Posted October 19, 2013 Author Share Posted October 19, 2013 pulled carpet back no wetness so heater matrix looks good no powder or wetness from around the pulley checked hoses again today all look good no oil or water mix so head gasket looks good am out of ideas now Quote Link to comment Share on other sites More sharing options...
