Krzys Posted May 15, 2014 Share Posted May 15, 2014 On 5/15/2014 at 2:22 PM, Grant said: Good thoughts Damn it! Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted May 15, 2014 Share Posted May 15, 2014 On 5/15/2014 at 2:22 PM, Grant said: b18c4 with a tdo4 (thats tt & s3 turbo isnt it?) would work well.. Obv with the right set up, decent intercooler, wastegate, injectors, chipped p28 etc etc will see a realiable 240 all day ..Yep, that should be easily achievable without running too much boost at all so room to go further if you want to later. Quote Link to comment Share on other sites More sharing options...
Carbon Addict Posted May 15, 2014 Author Share Posted May 15, 2014 I have been told the d16 vtec is a good engine to turbo and cheap aswell? Quote Link to comment Share on other sites More sharing options...
Grant Posted May 15, 2014 Share Posted May 15, 2014 Yeah there is a massive following for turbo D's. Non on here I don't think. But they are done pretty realibly too! On 5/15/2014 at 4:03 PM, NIKH25 said: Yep, that should be easily achievable without running too much boost at all so room to go further if you want to later.Exactly Nick, by all accounts, obv I've not personally tested it, but pretty sure the stock c4 will take 300 reasonably easy Quote Link to comment Share on other sites More sharing options...
Carbon Addict Posted May 15, 2014 Author Share Posted May 15, 2014 Lots of research and saving I think lol. Brakes and handling 1st. Gotta stop! Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted May 15, 2014 Share Posted May 15, 2014 On 5/15/2014 at 5:04 PM, Grant said: Yeah there is a massive following for turbo D's. Non on here I don't think. But they are done pretty realibly too!Exactly Nick, by all accounts, obv I've not personally tested it, but pretty sure the stock c4 will take 300 reasonably easy Yes, should do I think as long as it's strong to start with, a turbo D series will work well too and should get similar power done right. A rebuilt block with upgraded internals will see even more, check out Rich's (civicturbo79) old build, 379bhp!! loads of vids on you tube. On 5/15/2014 at 5:28 PM, Carbon Addict said: Lots of research and saving I think lol. Brakes and handling 1st. Gotta stop! Research is good, find out what will work best for you, especially if you're keeping it as a daily. Stopping sounds like a good place to start. Quote Link to comment Share on other sites More sharing options...
Grant Posted May 15, 2014 Share Posted May 15, 2014 Always helps to be able to stop! Lol Research is a must. There are so many builds out there, good and bad that you can learn from! Defo learn from others mistakes and don't make the same ones! Quote Link to comment Share on other sites More sharing options...
Krzys Posted May 15, 2014 Share Posted May 15, 2014 On 5/15/2014 at 6:12 PM, NIKH25 said: A rebuilt block with upgraded internals will see even more, check out Rich's (civicturbo79) old build, 379bhp!! loads of vids on you tube.That sort of power could be pretty wasted though, imagine it wouldn't be able to put it down very well without being on a straight, be like owning a muscle car Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted May 15, 2014 Share Posted May 15, 2014 On 5/15/2014 at 6:42 PM, Krzys said: That sort of power could be pretty wasted though, imagine it wouldn't be able to put it down very well without being on a straight, be like owning a muscle car That's true, could be a bit of a handful in the wet. A bit like having 500hp in an rx7 awesome in a straight line but will not go round corners. Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted May 15, 2014 Share Posted May 15, 2014 On 5/15/2014 at 7:06 PM, UnicyclingTom said: Then holding up 6 200bhp ish hondas! while on this topic that new sig is looking top notch! 1 Quote Link to comment Share on other sites More sharing options...
