vtec2011 Posted December 23, 2013 Share Posted December 23, 2013 Love how some proper kit going on this M... I was going to mention about the reflectors/lenses in the headlights but obviously it shows the light was all over the place! Does look cool without the reflectors/lenses though 1 Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted December 23, 2013 Share Posted December 23, 2013 new exhaust looks so much nicer! and love the new wheels so much more OEM+ I think the vtis kit would look better if it was colour coded. 1 Quote Link to comment Share on other sites More sharing options...
hubert Posted December 24, 2013 Author Share Posted December 24, 2013 prefer the new wheels bud.what did you do to treat the rust?i had it cut out and replaced,the sealed and coated. Quote Link to comment Share on other sites More sharing options...
hubert Posted December 24, 2013 Author Share Posted December 24, 2013 Are we nearly up to date yet? yes,@ this point i started messing around with the Aerodeck when i should be spending on the MB6,all influenced by Alex and Ollie lol. 1 Quote Link to comment Share on other sites More sharing options...
hubert Posted December 24, 2013 Author Share Posted December 24, 2013 new exhaust looks so much nicer! and love the new wheels so much more OEM+ I think the vtis kit would look better if it was colour coded.i will be colour coding it,still trying to get some quotes for a full respray Quote Link to comment Share on other sites More sharing options...
hubert Posted December 24, 2013 Author Share Posted December 24, 2013 (/) =done MB6 Project Banzai PublicFriendsOnly meCustomClose FriendsLimited ProfileSee all lists...TK MaxxHouse of FraserFamilyVieux-Fort Comprehensive Secondary SchoolDynotech hayes engineeringMonsterrat SecondaryAcquaintancesGo BackEngine RebuildYonaka Aluminium radiator & fan / Mishimoto Thermostat /Mishimoto fan Switch Mishimoto Oil Catch TankMishimoto Silicone Radiator HoseMishimoto Straight Silicone Coupler - 2.5"Mishimoto IntercoolerMishimoto Radiator Fan and Shroud Kit.Mishimoto Performance Aluminium Radiator Type-R crankshaft/Eagle H rods/ACL race bearing /Striped clean and potted engine block/ Skunk2 standard compression value/CP low compression pistons/ BC valve springs / BC titanium retainers/ BC stage2 cam shaft/ AEM Tru-Time Cam Gear/Blueprint water-pump/ Blueprint timing belt/ Golden Eagle block guard /ACT stage 2 clutch/ ACT flywheel / Procharged SuperchargerC1-A/ Wallbro fuel pump / skunk2 fuel rail/ Recondition cam cover / Maga core spark plug cable ./ NGK spark plugs / Torque exhaust 100 cell cat/ now removedSkunk2 Maga flow exhaust ./ now removed4-1 exhaust header/3" exhaust piping/ Fuelab fuel regulator/ID fuel 725 injector/ injector clips /Edelbrock intake manifold /BLOX Racing billet throttle body 74mm/Fabricated inter-cooling pipe /Tial 50MM Dump value/MSD Ignition Pro-Billet Distributor MSD extreme distributor cap kit Unorthodox ultra as pulley set . Customer Made Ground System (Earthing Kit) Wires/ Hasport Motor Mount Procharger pulley/Intake Manifold gasket / Exhaust Manifold gasket /Black braided fuel hose £10Goodridge Black Historic Female Hose End Fitting/Buddy club battery. HB057 battery Halfords // Suspension Rota GT3 (red)/ goneWilwood big break kit Respray Gold callipers Drilled & grooved break dics Adjustable coilovers MiesterR£400/BC658.20Function7 Lower Control arms Skunk2 camber kit(front & rear)/ Function7 rear brace & sway bar kit JDM SPORT wheel lug nuts Body Work champion White respray . JDM yellow HID fog lights/ removedPassword JDM front & rear tow hooks Yellow smoke out head light vinyl flim/ removeWire tuck/Engine respay/Electronic Rtect P28 ECU Tuning,Mapping & Dyno / AEM boost gauge AEM air/fuel/ratio gauge/ AEM oil pressure gaugeAEM oil temperature gaugeAEM water temperature gaugeMilage of Rebuild 111,461 Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted December 24, 2013 Share Posted December 24, 2013 Impressive spec list. At the beginning of the thread you mentioned the pro charger acts like a turbo, is it still belt driven? Quote Link to comment Share on other sites More sharing options...
hubert Posted December 24, 2013 Author Share Posted December 24, 2013 Impressive spec list. At the beginning of the thread you mentioned the pro charger acts like a turbo, is it still belt driven? yes,it's belt driven 1 Quote Link to comment Share on other sites More sharing options...
hubert Posted December 24, 2013 Author Share Posted December 24, 2013 On the list it says mister r suspension, yet in the pictures it tiens?the list was made, but i changed things as i go and things that wasn't on the plan had to be done so i always have to update the list,and there are so much more to come,hoping that i get alot done in 2014. Quote Link to comment Share on other sites More sharing options...
10000rpm Posted December 24, 2013 Share Posted December 24, 2013 Nice build dude, whats wheelspin like? Also hows the power delivery?News wheels look lush 1 Quote Link to comment Share on other sites More sharing options...
