Closing the Sunroof
skymera
This is pretty dumb... I can't figure out how to close the sunroof fully?
There's a button, not sure what it does? It just opens the sunroof when I pressed it.
And there's a switch, one way opens back and other opens upward.
If I close it one way and hold the switch too long it opens the other.
Am I being stupid?  :???:  :???:  :oops:
It should work thus: pull the slider back it opens fully, push the slider forwards it closes, push the button and it tilts.
If when you are pushing the slider forwards it closes and then tilts, there must be a problem with the switch.
Tested with some more confidence and it works correctly ;)
When closing it lifts up slightly then down and locks
This thread can be closed
That's right, because when you slide it back it tilts down slightly so the glass can hide under the roof skin :)
So when you slide it back forward the upward motion is it moving back to the closed position.
