GreenVTi991 Posted January 30, 2014 Share Posted January 30, 2014 My Civic has recently suffered from water ingress concentrated in the top corners of the roof lining above the A pillars. After searching on here I took the plastic gutters off the roof and the job underneath is mint - not a spec of rust in sight! I then took the A pillar trims and sun visors off, pulled the headlining down and checked the sunroof drain holes - mint with no leaks! I've also had a look at the metal above the top windscreen seal and cannot see any telltale signs of rust bubbling beneath it. Even more confusing is since taking the interior apart a couple of weeks ago I've not put it back together to see where the water has been getting in and it's all dried out! Where's left to check as I'm stumped?! Quote Link to comment Share on other sites More sharing options...
Aerodeckcivic Posted January 30, 2014 Share Posted January 30, 2014 Sunroof Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 30, 2014 Share Posted January 30, 2014 The windscreen is bonded in, the seal has probably gone.I thought the same about mine, but it was actually leaking at the tailgate seal! Then condensation builds up and makes it look like it's coming from the windscreen! Quote Link to comment Share on other sites More sharing options...
GreenVTi991 Posted January 30, 2014 Author Share Posted January 30, 2014 Ooh maybe that's what's happening to mine! I drove through really heavy rain on the way home earlier and there wasn't a drop of water on the inside of the windscreen seal. I'll check the tailgate tomorrow Quote Link to comment Share on other sites More sharing options...
Roj Posted January 30, 2014 Share Posted January 30, 2014 I'm having the same problem, but I know it's the sunroof because mine doesn't close properly. Quote Link to comment Share on other sites More sharing options...
GreenVTi991 Posted January 30, 2014 Author Share Posted January 30, 2014 Yeah mine has never worked properly either so I use the manual handle to wind it shut. But surely if it's not sealing properly the drain holes will take care of any excess water? Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 30, 2014 Share Posted January 30, 2014 I would have thought that with the headlining out you'd have spotted any leaks from the sunroof or screen already, I left mine out for a week after trying it with kitchen roll to see if I could find where mine was coming from! Quote Link to comment Share on other sites More sharing options...
GreenVTi991 Posted January 30, 2014 Author Share Posted January 30, 2014 Indeed but I've not seen any leaks from sunroof or windscreen. It's chucking it down outside right now so hopefully tomorrow morning I can pinpoint where the leak is. Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 31, 2014 Share Posted January 31, 2014 Yeah, I had the same when the headlining was out, would driving it while it was p1ssing it down and couldn't suss any leaks at all! My headlining was pretty ruined at the back of the car which pointed me to that end to check for leaks but with a dry boot I ruled out the tail light seal and the only other bit was the thick black rubber the tailgate uses to form a seal! I noticed pretty quickly it had helped! Though my car isn't yet properly sorted in that area as I have since noticed that the replacment rubber isn't tip top but it was free and loads better than what I had! Will be buying brand new from Honda when money allows! I plan to replace all five weatherstrips and all four door seals! Should be sorted then! 2 Quote Link to comment Share on other sites More sharing options...
simpo Posted February 6, 2014 Share Posted February 6, 2014 If it's the tailgate seal why doesn't it happen on the other side? Quote Link to comment Share on other sites More sharing options...
