Steve's MB2 - MG ZS Trim installed at last (Pics page 3)
casasteve
  • 4 weeks later...
So, back in the country. Had a bit of a s**t time of it so throwing myself at the car as a distraction.
So, I came home to a flat battery so I whipped that out and charged it.  When I hooked it up the central locking went nuts.  So, clearly that's why the fuse had been removed by a previous owner.  So I've got to pull out the IR receiver and check for corroded wiring etc.
I've just ordered discs and pads for all corners.  I opted for Brembo discs and pads but nothing fancy.  Hopefully I can do the work myself.
Also, still got to do the brake bleed, transmission fluid change and oil/oil filter change.  Then air filter and cabin filters also.
I'm sort of half looking out for some cheap 16" wheels/tyres but I think I should save the funds for more of the mechanicals at the moment.  I really should get the cam belt sorted...
Oh, and when I moved the car for the first time, I'm pretty sure the front left calliper had seized on.  I got a good clunk noise as it freed itself.  Since, it's been giving me a ticking sound as the pad rubs on the disc in one spot.  I'm going to drive it this week and see if it frees up some more, as I don't do many miles normally.  If not, I'll take a look at the weekend and see if I can do anything.
Calipers do tend to stick when stood for a while! When you do the brakes could be worth checking the piston moves freely! I know the rears need winding rather than just sliding, not sure if the fronts are the same or not!
