Aerocrap VTI from Slovenia
Hakosuka
Over the last couple of weeks did some more work on the car.
I needed to replace my radiator as it had a slight leak. I got it second hand (almost new) for 110€ with the slim fan.
Then I broke the CV joint and pulled the box off the car (I though it's the gearbox' fault for crunching). While I was at it I pulled the clutch and it was pretty bad. The metal around the springs was chipped off, so I ordered an Exedy OEM replacement unit and replaced that with couple other things:
I changed the halfshaft oil seal and the crank oil seal:
I also replaced the flywheel bearing as it was really f**ked up. Barely moving. Looks like it wasn't the sealed type which is bad.
And now some pics of the car, so you don't forget how crappy it is:
And another one with my 3rd car:
The R33 is portly compared to a 'Deck! lol
Dude, it's a R34! It's a GTT though  :rolleyes: Only two Skylines in Slovenia :)
I could tell it was a 34GTT! :roll:
Both look good though! Nice bit of TLC going on!
