NIKH25 Posted April 24, 2014 Share Posted April 24, 2014 I went to get a 4 wheel alignment done this afternoon, unfortunately their ramp was s**gged and wouldn't lock in place so the car was leaning to one side so it couldn't be done. However the chap there has asked me to seek advice as to what camber I should be running on the rear, it looks like the front will be around 2 deg. Anybody got any suggestions? Cheers guys. Quote Link to comment Share on other sites More sharing options...
3gdean Posted April 24, 2014 Share Posted April 24, 2014 Have you got camber adjusters? Don't think they adjust without.I'd say just match the fronthttp://yospeed.com/wheel-alignment-explained-camber-caster-toe/ Quote Link to comment Share on other sites More sharing options...
Chandler Posted April 24, 2014 Share Posted April 24, 2014 im running about 4 degrees at the minute Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted April 24, 2014 Author Share Posted April 24, 2014 Have you got camber adjusters? Don't think they adjust without.I'd say just match the fronthttp://yospeed.com/wheel-alignment-explained-camber-caster-toe/ I don't want to match the front, it's not recommended as it will upset the balance. im running about 4 degrees at the minute Yes, well you need that just to get them under the arches. Quote Link to comment Share on other sites More sharing options...
Chandler Posted April 24, 2014 Share Posted April 24, 2014 I don't want to match the front, it's not recommended as it will upset the balance.Yes, well you need that just to get them under the arches.ha ha i know will be needing more camber soon i recon 1 Quote Link to comment Share on other sites More sharing options...
Grant Posted April 24, 2014 Share Posted April 24, 2014 Mines running 3.5 degs. Which is probably too much. Want it to around the fronts, the guy that did mine (honda mentalist & expert) said he'd like to get the rears to about 1.8-2.0 - http://www.performance-autoworks.co.uk/index.phpTry and ask your bloke to dial in a little toe in on the rear too. Assists in turn in. Too much though and the rear will become a little restless. Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted April 24, 2014 Author Share Posted April 24, 2014 Mines running 3.5 degs. Which is probably too much. Want it to around the fronts, the guy that did mine (honda mentalist & expert) said he'd like to get the rears to about 1.8-2.0 - http://www.performance-autoworks.co.uk/index.phpTry and ask your bloke to dial in a little toe in on the rear too. Assists in turn in. Too much though and the rear will become a little restless.Cheers, so I probably want a bit less maybe 1.2-1.5 if I have 2.0 on the front? Quote Link to comment Share on other sites More sharing options...
Grant Posted April 24, 2014 Share Posted April 24, 2014 Cheers, so I probably want a bit less maybe 1.2-1.5 if I have 2.0 on the front?From his logic mate yes. Plus a little 0.5 degree toe in and she should handle a treat! 1 Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted April 24, 2014 Author Share Posted April 24, 2014 From his logic mate yes. Plus a little 0.5 degree toe in and she should handle a treat!Perfect, thanks chap. :D 1 Quote Link to comment Share on other sites More sharing options...
Grant Posted April 24, 2014 Share Posted April 24, 2014 What rubber are you running with her mate? Quote Link to comment Share on other sites More sharing options...
