dr_broon Posted November 22, 2014 Share Posted November 22, 2014 evening. Finally picked up the ECU after getting it socketed and chipped, and the IAB components added. Plugged it in and got an engine light. have read the code and it's 13 - Baro Atmospheric Pressure Sensor. from what I can gather, this seems to be a sensor that USDM ecus have... and my P28 probably doesn't. http://www.hondata.com/forum/viewtopic.php?t=933 So I'm thinking that the P72 map on the chip is looking for the APS and it's throwing the code coz it's not there... anyone know if I can run the ECU with this fault showing until I can get it to someone who can disable it in the map? WIll it cause any problems or should I just swap the P9 back in. Cheers Quote Link to comment Share on other sites More sharing options...
Grant Posted November 22, 2014 Share Posted November 22, 2014 Wish I could help mate. But don't know a lot about these. Hope you get it sorted though. Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted November 23, 2014 Share Posted November 23, 2014 On 11/22/2014 at 9:24 PM, dr_broon said: evening. Finally picked up the ECU after getting it socketed and chipped, and the IAB components added. Plugged it in and got an engine light. have read the code and it's 13 - Baro Atmospheric Pressure Sensor. from what I can gather, this seems to be a sensor that USDM ecus have... and my P28 probably doesn't. http://www.hondata.com/forum/viewtopic.php?t=933 So I'm thinking that the P72 map on the chip is looking for the APS and it's throwing the code coz it's not there... anyone know if I can run the ECU with this fault showing until I can get it to someone who can disable it in the map? WIll it cause any problems or should I just swap the P9 back in. Cheers Hmmmm, tricky. Not sure if this helps, but I've been looking at running throttle bodies with mine on a socketed P30 ECU where some of the sensors will be useless so we (well mainly the guy putting my engine together) was going to switch off the sensor and run the engine on the TPS and revs so it must be possible. Can your tuner not do anything on the map? If our engines don't run the same sensors as the USDM version then I'd guess it can be turned off in the code? 1 Quote Link to comment Share on other sites More sharing options...
dr_broon Posted November 23, 2014 Author Share Posted November 23, 2014 Got a bit of a problem worry that though... Got the chip with the p72 map from the states... Just had someone local to do the soldering work. Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted November 23, 2014 Share Posted November 23, 2014 On 11/23/2014 at 1:29 PM, dr_broon said: Got a bit of a problem worry that though... Got the chip with the p72 map from the states... Just had someone local to do the soldering work If it's chipped with Hondata, Chrome etc then it should be switchable by the right tuner but maybe need a retune after? I was going to use Romain (races in Time Attack, contacted him through R-Motion) to do my P30 before I changed my mind and went to a DTA S60 Quote Link to comment Share on other sites More sharing options...
dr_broon Posted November 23, 2014 Author Share Posted November 23, 2014 True... Just need to find someone to do it i suppose. Was hoping to be able to try it out, but have played safe and swapped the p9 back in. Quote Link to comment Share on other sites More sharing options...
dr_broon Posted November 23, 2014 Author Share Posted November 23, 2014 Found some useful engine fault code info here :http://www.marklamond.co.uk/tech-honda/pgm-fi/ecu-codes/ecu-code-list.htmListed below in case the page disappears.Fault Codes ExplainedThis page explains what each of the PGM-Fi fault codes means, the implications on operation of the ECU when running under the fault condition, and comments on typical causes for the fault.To read how to obtain fault codes from your vehicle, please take a look here.If you have any corrections with the details held here or have the description of a fault code not listed, please get in touch!1Oxygen Sensor "A" (Primary)Honda say Defective circuit or unplugged / defective sensor.Implications ECU will probably not run in closed loop operation.Comment With OBD-0 VTEC ECU's such as the PW0 and PR3 that run two primary oxygen sensors (one for each pair of cylinders) make sure you have the correct sensor in the correct manifold boss!2Oxygen Sensor "B"Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment More details to follow. Secondary oxygen sensor's purpose is typically to monitor the performance of the catalytic converter.3MAP Sensor (Manifold absolute pressure)Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment To follow, please see details for fault code 5.4CKP Sensor (Crankshaft position)Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment To follow.5MAP Sensor (Manifold absolute pressure)Honda say Defective circuit or unplugged / defective sensor / incorrect pipework.Implications ECU will run TPS based routine.Comment The MAP sensor is the primary load input, and on failure the ECU will run some form of substitution based on the TPS input. Engine will run, although generally not idle and performance is severely impaired. Do not run the engine any longer than required to get the car to a repair shop.6ECT Sensor (Engine coolant temperature)Honda say Defective circuit or unplugged / defective sensor.Implications ECU will ignore the input if it is not within range, and substitute a fixed value.Comment Fixed value substituted when input is not in range varies depending on engine RPM - commonly 85°C during normal operation, although this is raised during cranking.7TP Sensor (Throttle position)Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment Incorrect adjustment or failure of the TPS sensor or wiring issues will cause a number of problems, mainly idle related. Details of adjustment procedure to follow.8TDC Sensor (Top dead centre)Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment To follow.9CYP Sensor (Cylinder position)Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment To follow.10IAT Sensor (Intake air temperature)Honda say Defective circuit or unplugged / defective sensor.Implications ECU will ignore the input if it is not within range, and substitute a fixed value.Comment Details of fixed value used to follow.11IMA Sensor (Idle mixture adjust)Honda say Defective circuit or unplugged / defective sensor.Implications Probably substitution of fixed value if input is not within range.Comment Sometimes known as the CO Pot. This is fitted to OBD-0 ECU's in some vehicles that do run an lambda sensor. This only applies to some some markets, like the UK where fitting of a catalytic converter was not law until 1991. The input is simply a potentiometer that is used to trim the base fuelling - hence the name CO pot.12EGR Lift Sensor (Exhaust gas recirculation)Honda say Defective circuit or unplugged / defective sensor.Implications Unknown.Comment EGR is used for emission control.13BARO Pressure Sensor (Atmospheric pressure sensor)Honda say Defective circuit or unplugged / defective sensor.Implications ECU will ignore the input if it is not within range, and substitute a fixed value.Comment This sensor is commonly fitted with US and European ECU's, it is not normally found on JDM units. With OBD-0 ECU's this sensor is external to the ECU and on all later units (including OBD-0 VTEC ecu's such as the PW0) it is a small module fitted internally to the PCB.14IAC Valve (Idle Air Control)Honda say Defective circuit or unplugged / defective valve.Implications Unknown.Comment Only applies to vehicles equipped with an automatic transmission.15Ignition Output SignalHonda say Missing or defective ignition output signal.Implications To follow.Comment To follow.16Fuel Injector SystemHonda say Defective circuit or unplugged / defective sensor.Implications Unknown.Comment Problem with fuel injectors.17VSS (Vehicle Speed Sensor)Honda say Defective circuit or unplugged / defective sensor.Implications If engine is VTEC model, it will not be engaged.Comment Early 1990 VSS sensors as fitted to B series engined MK2 Integra's and MK2 CRX's are prone to failure - the design was modified and late 1991-onwards vehicles rarely get VSS problems.18Ignition TimingHonda say Unknown.Implications Unknown.Comment Not quite sure about this one!19Automatic Transmission Lock Up Control Solenoid ValveHonda say Defective circuit or unplugged / defective solenoid valve .Implications Unknown.Comment Only applies to vehicles equipped with an automatic transmission.20ELD (Electrical Load Detector)Honda say Defective circuit or unplugged / defective solenoid valve .Implications Unknown.Comment This is a solid-state hall effect current sensor, commonly mounted in the engine compartment's fuse box (normally located on top of a suspension turret) and it's purpose is to monitor current demand for precise emission control.21VTEC Solenoid ValveHonda say Defective circuit or unplugged / defective solenoid valve.Implications VTEC will not be engaged, no high cam lobes.Comment Solenoid, or "spool" valve that allows oil to flow into the VTEC mechanism. VTEC will obviously not operate and engine will feel breathless at higher RPM's. High RPM driving should be avoided as the engine will only be operating on the low speed lobes.22VTEC Oil Pressure SwitchHonda say Defective circuit or unplugged / defective pressure switch.Implications VTEC will not be engaged, no high cam lobes.Comment This switch was only used on early VTEC engines - note it is not to be confused with the oil pressure switch. Commonly caused by idiots who don't check their oil level - so if it flashes up during hard cornering or braking then stop and immediately and check the dipstick! The VTEC mechanism is operated hydraulically from the engine's main oil supply and when it is first engaged causes a momentary fluctuation in oil pressure, and demand on the pump - if pressure available to the VTEC mechanism is not high enough, it will disable VTEC.23KS (Knock Sensor)Honda say Defective circuit or unplugged / defective pressure sensor.Implications To follow.Comment ECU will be unable to trim ignition timing to adapt for differing environmental conditions, and quality of fuel.30Automatic Transmission Signal "A" SEAF / SEFA / TMA or TMBHonda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment To follow.31Automatic Transmission Signal "B"Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment To follow.41Primary Oxygen Sensor - HeaterHonda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment To follow.43Fuel Supply System - Oxygen Sensor (A)Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment This is generally flagged when the engine is running either very rich, or lean due to a mechanical problem, or very bad tuning. Based on Lambda sensor input to some extent. Get a wideband AFR meter on the car - also check your injectors and fuel pressure.44Fuel Supply System - Oxygen Sensor BHonda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment See fault code 43.Only a small number of Honda vehicles use a "B" O2 sensor such as the first generation B16A engines (PW0 ECU) and some V6 models. Each O2 sensor is responsible for a group of cylinders and during closed loop operation fuel delivery to each group of cylinders is trimmed independently.Because of this it is absolutely imperative that you have each O2 sensor in it's respective manifold port. If you mix up the sensor locations or wiring the ECU will alter the fuel delivery for the wrong cylinder bank. This can result in hesitation and misfires during light to moderate loads.48LAF Sensor (Lean Air Fuel)Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment To follow.54CKF Sensor (Crankshaft Speed Fluctuation)Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment This sensor is mounted behind the timing belt sprocket on the crank, and used to closely monitor the speed of the crank to detect a misfire etc. Only fitted to OBD-2 systems.58TDC Sensor 2 (Top Dead Centre)Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment To follow.61Oxygen Sensor, Heated - Sensor 1 (Primary)Honda say High voltage, low voltage or slow response.Implications To follow.Comment To follow.63Oxygen Sensor, Heated - Sensor 2 (Secondary)Honda say High voltage, low voltage or slow response.Implications To follow.Comment To follow.65Oxygen Sensor Heater (Secondary)Honda say Defective circuit or unplugged / defective sensor.Implications To follow.Comment To follow.67Catalyst System Efficiency Below ThresholdHonda say Malfunctioning or defective catalyst system.Implications To follow.Comment To follow.70Automatic TransmissionHonda say Malfunction with the automatic transmission controls.Implications To follow.Comment To follow.71Cylinder 1 Missfire or a Random MissfireHonda say A condition is present that is creating a cylinder misfire.Implications To follow.Comment To follow.72Cylinder 2 Missfire or a Random MissfireHonda say A condition is present that is creating a cylinder misfire.Implications To follow.Comment To follow.73Cylinder 3 Missfire or a Random MissfireHonda say A condition is present that is creating a cylinder misfire.Implications To follow.Comment To follow.74Cylinder 4 Missfire or a Random MissfireHonda say A condition is present that is creating a cylinder misfire.Implications To follow.Comment To follow.75Cylinder 5 Missfire or a Random MissfireHonda say A condition is present that is creating a cylinder misfire.Implications To follow.Comment To follow.76Cylinder 6 Missfire or a Random MissfireHonda say A condition is present that is creating a cylinder misfire.Implications To follow.Comment To follow.80Exhaust Gas RecirculationHonda say Insufficient flow detected.Implications To follow.Comment To follow.86ECT Sensor (Engine Coolant Temperature)Honda say Insufficient flow detected.Implications To follow.Comment To follow.90Evaporative Emission Control SystemHonda say Leak detected in the fuel tank area.Implications To follow.Comment To follow.91Fuel Tank Pressure SensorHonda say Low input.Implications To follow.Comment To follow.92Evaporative Emission Control SystemHonda say Insufficient purge flow.Implications To follow.Comment To follow.. 1 Quote Link to comment Share on other sites More sharing options...
noodels Posted November 23, 2014 Share Posted November 23, 2014 Did you take the knock board out ?page 2http://cars.homenetcs.co.uk/honda-civic-mb6/modifications-ecu.htm Quote Link to comment Share on other sites More sharing options...
dr_broon Posted November 23, 2014 Author Share Posted November 23, 2014 Don't think that the p28 has a knock board? Will check that out though Quote Link to comment Share on other sites More sharing options...
noodels Posted November 24, 2014 Share Posted November 24, 2014 opps! just saw p72.. Quote Link to comment Share on other sites More sharing options...
