Rear subframe brace options
DeLaSoul
Well I will know by the weekend if this will fit.  Got some interference fit plug turned out of aluminium and pressed them into the brace (with a little industrial bearing lock for good measure) and put it all on the mill ready to flush cut the plug.  Then drill the new holes in the brace and hopefully fit it on the chassis by the weekend, or have an expensive paperweight for my desk!
Some :)
Finished off the plugs and counterbored the new holes approx 5mm in per side to match the measurements on the chassis
So the brace goes on the chassis (just) but hits the rear ABS sensor bolt holes so didn't sit flush with the subframe :(
So angle grinder to the rescue (I hate cutting the chassis!)
Brace now sits flush and I could drill the ARB holes in the subframe.  AS you can see the upper hole in the frame still sits off the subframe so I'll machine a small spacer to make up the difference.
Next job is to make up some infill pieces for the sub frame, weld them in and paint over.  The kit came with a piece to mount inside the subframe to give threaded inserts to bolt the ARB to, these too have to modified slightly but that's 5 minutes with a saw and a file.  Too much work, wouldn't recommend this to anyone!
  • Like 3
