JK1245 Posted January 25, 2015 Share Posted January 25, 2015 Hello again guys, so today I'm driving around in 4th gear and the car starts stuttering so I give it a bit more fuel and it keeps stuttering but then all of a sudden stops and the car starts driving normally again. Engine pulls fine, no smoke in Vtec or anything, however it does smell pretty rich. No check engine lights or anything. Anyone know what the problem could be? I'm leaning toward plugs + leads but I've also read that the Lambda sensor can be a bit dodgey? Thanks for the help guys. Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 25, 2015 Share Posted January 25, 2015 Check the plugs and leads first chap, but to me the points to ignition. Lambda usually throws a light, but not always because it's nice like that Check the basics bits first and see what you find. 1 Quote Link to comment Share on other sites More sharing options...
Grant Posted January 25, 2015 Share Posted January 25, 2015 as above really mate! Quote Link to comment Share on other sites More sharing options...
JK1245 Posted January 25, 2015 Author Share Posted January 25, 2015 Cheers lads, I've also got cone filter on it with no heat shield, could it be heat soak or anything? Will have a look at the plugs tomorrow but if they do need replacing what are a good set for the B18C4? Again, thanks for the help Quote Link to comment Share on other sites More sharing options...
beastgtir Posted January 26, 2015 Share Posted January 26, 2015 Sounds like early symptoms of dizzy failure buddy Quote Link to comment Share on other sites More sharing options...
Grant Posted January 26, 2015 Share Posted January 26, 2015 Cheers lads, I've also got cone filter on it with no heat shield, could it be heat soak or anything? Will have a look at the plugs tomorrow but if they do need replacing what are a good set for the B18C4? Again, thanks for the help Wont be heat soak mate .. Unless its stuplidly close to Mani .. I just use the recommended copper NGK's mate .. Quote Link to comment Share on other sites More sharing options...
kern Posted January 30, 2015 Share Posted January 30, 2015 check injector plugs too! Quote Link to comment Share on other sites More sharing options...
JK1245 Posted January 30, 2015 Author Share Posted January 30, 2015 Been driving it for the past few days and had no problems with it, but it came back for a few seconds today. It's having a major service carried out tomorrow so hopefully it'll sort everything out. Bought some of that injector cleaner as well and I'll make sure the plugs are all in properly. Thanks for the help fellas. 1 Quote Link to comment Share on other sites More sharing options...
