My Civic MB2 Build sort of
CathalC
looks good man,
got a bit close to that water though didn't you!! foot on brake aswel as the handbrake on?
Yea foot brake and handbrake M's handbrake is like choclate on a frying pan! haha.
Thanks mate
  • 2 months later...
  • 3 weeks later...
Hi guys,
Just quick question do the trailing arms with the disk brakes fit on the MB2 i seen in  the parts list that the drum brakes cant be converted to disks.
does this mean that i cant swap the entire trailing arm with disks to make it work?
  • 2 weeks later...
OK so before i put the d16y8 into my car i have ordered a few parts for it.
Head gasket kit including all seals (Will be using genuine honda cam seals tho)
Timing belt and water pump kit
Shell bearings
All is coming to Euro450 but that includes to OEM Headlights 140 quid a pop!
  • 2 weeks later...
Not sure about abs codes sure there will be someone here knows.
But answer previous question you can swap trailing arms. To have discs. Prop valve from disc car probably a good idea too
