Gel Posted May 17, 2015 Share Posted May 17, 2015 You know how it goes.....your Check Engine Light illuminates.....you switch it off or have a mechanic do it for you.......it comes on again within a few hundred miles or actually stays on after clearing the troublesome code.....so you fit an affordable universal Lambda sensor only to find you still have problems (for some strange reason Honda's don't get on with cheap universal sensors). A Honda sensor will cost circa £200 + (silly money to spend on an ageing car).....whilst researching Civics I came across these OE Denso oxygen sensors : http://www.micksgarage.com/search.aspx?fffBrand=Denso&fffDepartment=Lambda%20Oxygen%20Sensors&fffMake=honda&fffBasemodel=honda%20civic&fffModelDescription=civic%20mk%20iv%20hatchback%201994%20to%202001&ffftd_car=1.4%20i%20(ma8)&fffBHP=90 I'm not affiliated to the above Company in any way but I will be sourcing a Lambda from 'em if ever needed in the future. 1 Quote Link to comment Share on other sites More sharing options...
Gel Posted May 17, 2015 Author Share Posted May 17, 2015 Whilst on the subject of Lambda's............Modders , Tuners or folk with a naff CAT may be interested in this downstream spacer : http://www.evolutionm.net/forums/evo-how-requests-questions-tips/114931-how-install-spark-plug-anti-foulers-remove-ses-cel-light.html It'll get rid of the pesky CEL and allow you to reset your fuel values. Quote Link to comment Share on other sites More sharing options...
Krzys Posted May 17, 2015 Share Posted May 17, 2015 Good find! Should be useful! Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted May 17, 2015 Share Posted May 17, 2015 Nice. Quote Link to comment Share on other sites More sharing options...
Gel Posted May 18, 2015 Author Share Posted May 18, 2015 I amended the link in my 2nd post..........this is what I meant to post :http://www.evolutionm.net/forums/evo-how-requests-questions-tips/114931-how-install-spark-plug-anti-foulers-remove-ses-cel-light.html A friend sourced and fittedhttp://www.ebay.co.uk/itm/LAMBDA-O2-OXYGEN-SENSOR-EXTENDER-SPACER-FOR-DECAT-HYDROGEN-M18-Stainless-Steel-/170909875264Worked a treat Quote Link to comment Share on other sites More sharing options...
