CRV gearbox ratio swap
jamesvti
So, from what I understand all b series gearbox bits are interchangeable APART FROM the itr final drive needs the itr 1st gear to fit on the shaft (even though the ratio is the same as in the s9b) which I found out halfway through getting the install done.
As krzys says, not aware of a crv gearbox being plundered for bits.
People do use the b20 in civics with a vtec conversion, but not sure if they use the b20 gearbox or something else.
Might be worthwhile looking at crv forums to see if anyone's used other b series gears in there crv gearbox... That might point you in the right direction.
heres the info on ratios ive found....
crv                                s9b
1st 3.5                          3.230
2nd 1.956                     1.900
3rd 1.344                      1.360
4th 1.071                      1.034
5th .812                         .848
fd  4.562                       4.266
i dont know much about ratio's except, the higher the fd the quicker the exceleration.
i can pick up a whole crv for £100 :D
these ratios are from 98-01 years crv's
