Ry4nC Posted February 10, 2016 Share Posted February 10, 2016 Thought I'd ask the question because I don't have a clue about it.What are the pro's and con's of heat wrapping the manifold?Is there any point?My manifold looks quite shocking but is functioning normally. I was thinking of stripping it of its accumulation of rust and s**t.. Paint it and then wrap on top.. Quote Link to comment Share on other sites More sharing options...
dr_broon Posted February 10, 2016 Share Posted February 10, 2016 Two things a far as i know. Helps keep engine bay temp down, and keeps exhaust gases got, which means they flow faster. Quote Link to comment Share on other sites More sharing options...
Ry4nC Posted February 10, 2016 Author Share Posted February 10, 2016 Oohhh.... might have to do it then!!! Quote Link to comment Share on other sites More sharing options...
Jayhoath83 Posted February 10, 2016 Share Posted February 10, 2016 Yep its worth it on tubular manis Quote Link to comment Share on other sites More sharing options...
EmZvr Posted February 10, 2016 Share Posted February 10, 2016 Anyone have any real evidence that it helps? When I researched this mod years ago I did not find any. Also this stopped me: http://www.centuryperformance.com/exhaust-header-heat-wraps-do-not-use.html Quote Link to comment Share on other sites More sharing options...
Krzys Posted February 11, 2016 Share Posted February 11, 2016 I would say realistically on your 1.4 it's not worth doing unless you want it for the look. Quote Link to comment Share on other sites More sharing options...
Ry4nC Posted February 11, 2016 Author Share Posted February 11, 2016 Tbf I don't think I would gain much on it so it would be mainly fro the look.. I suppose every little helps 1 Quote Link to comment Share on other sites More sharing options...
Krzys Posted February 12, 2016 Share Posted February 12, 2016 I scuffed the bottom of my manifold a couple of times and it fell off!What about the wrap? Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted February 14, 2016 Share Posted February 14, 2016 I scuffed the bottom of my manifold a couple of times and it fell off! same! and if you are going to do it, make sure the stuff is soaking wet (much easier to wrap round) and use metal zip ties 1 Quote Link to comment Share on other sites More sharing options...
EdGasket Posted February 16, 2016 Share Posted February 16, 2016 Does manifold wrap help with slightly leaking exhaust from a cracked manifold (this is on a Hyundai with a cast manifold) or would it just blow/burn straight through? The leak is not enough to have been spotted at MoT or to cause the emissions to fail. Quote Link to comment Share on other sites More sharing options...
