  • 0
Squeal on start up and at high revs
Dragonfly17
Hi I have recently had my cambelt / Spring and all 3 belts replaced on my 1.4 and a few weeks later have noticed a squeal on start up and you can hear it when at high revs in N . I have checked power steering fluid and it's on the minimum line so I will be toping this up before I use it again. What could the squealing be ? the cambelt was a Honda genuine part the others were from the garage who did the work
4 answers to this question
  • 0
8 hours ago, Gel said:
Your description seems to suggests...... your alternator belt needs tensioning ?
Cheers for  the advice I shall get all belts checked and tightened . I also found this on the plastic engine cover I'm not sure what it is
  • 0
Problem sounds like one of you auxiliary belts is a little on the loose side and needs  a little more tension.
The above pic is 1 row of fins from the bottom of the AC condenser. Nothing to be worried about they sag and fall off with age
Answer this question...
