hondasport Posted August 15, 2016 Share Posted August 15, 2016 I was wondering if this kit would fit our models. I think the bushings in the control arm will, but the one that connects to the subframe is a litte bit diffirent.http://www.all4honda.com/en/webshop/72-integra-1995-2000/93-suspension/932-pu-rubbers/hardrace-control-arm-bushings-front-lower-civic-del-sol-integra-details.html And I was looking for winter wheels and saw a set of a honda accord. These are 15" 4x114 and et50. But I don't know if there's gonna be enough clearance for the 282 brakes in the front. Quote Link to comment Share on other sites More sharing options...
Finch Posted August 15, 2016 Share Posted August 15, 2016 1 hour ago, hondasport said: I was wondering if this kit would fit our models. I think the bushings in the control arm will, but the one that connects to the subframe is a litte bit diffirent.http://www.all4honda.com/en/webshop/72-integra-1995-2000/93-suspension/932-pu-rubbers/hardrace-control-arm-bushings-front-lower-civic-del-sol-integra-details.html And I was looking for winter wheels and saw a set of a honda accord. These are 15" 4x114 and et50. But I don't know if there's gonna be enough clearance for the 282 brakes in the front. [Pic] 15" clear Brembo, Wilwood, Spoon and DC2 calipers with 282 disc, should be no issues The DC2 bushings etc do fit afaik, however energy suspension make bushings for our model Civic.. Theres a topic on it here > Hope this helps bud! 1 Quote Link to comment Share on other sites More sharing options...
hondasport Posted August 15, 2016 Author Share Posted August 15, 2016 thx for the wheels. yeah, but i'm more into the hardrace bushings that made out of rubber rather then pu. And I must have black ones otherwise I can't get trough mot inspection. Quote Link to comment Share on other sites More sharing options...
Finch Posted August 15, 2016 Share Posted August 15, 2016 2 minutes ago, hondasport said: thx for the wheels. yeah, but i'm more into the hardrace bushings that made out of rubber rather then pu. And I must have black ones otherwise I can't get trough mot inspection. OK, well the DC2 subframe and steering rack fit as far as I remember so HardRace should be OK Quote Link to comment Share on other sites More sharing options...
hondasport Posted September 16, 2016 Author Share Posted September 16, 2016 just looked for the suspension rubbers to renew. Here is what i think should work: rear lower control arms, hardrace normally for a ek civic:http://www.all4honda.com/webshop/13-civic-1996-2000/22-onderstel/328-pu-rubbers/hardrace-draagarmrubbers-achterzijde-civic-96-00-2-3-4drs-details.html front control arms and compliance bushing for an integra:http://www.all4honda.com/en/webshop/72-integra-1995-2000/93-suspension/932-pu-rubbers/hardrace-control-arm-bushings-front-lower-civic-del-sol-integra-details.html compliance bushing should normally be the same as the one on our chassis: Quote Link to comment Share on other sites More sharing options...
hondasport Posted November 17, 2016 Author Share Posted November 17, 2016 anyone knows if the front lca's bushing where the suspension arm is bolted the same as the one from a integra or eg? Because at the rear the suspension fork is 40mm and a eg is 50mm. Quote Link to comment Share on other sites More sharing options...
