Engine management wise I bought a chipped p28 ecu with a base map from h-tune, plugged it in and all was fine. Running well etc. Only drove a small amount and never over 5k rpm just to test as needs to be tuned.
One night I left the lights on a drained the battery, not even the clock was showing. I replaced the battery and since then it’s thrown an eml.
The fault code reads map sensor but it’s brand new.
If I turn the car on with the map sensor plugged in it’s starts but immediately dies, if I unplug the map sensor it’s starts and idles fine but is running rich. Is it possible that the map could have been wiped? Or ecu burnt out?
I’ve done all the work/mods to the car myself but I am stuck and don’t know how to fix this issue.
LurkinClassHeroes
Hi all. I’m new here.
I have a modified 1997 Honda Civic mb6 with a b18c4 that I did a turbo conversion on stock internals.
List is:
T3/T4 turbo, turbosmart wastegate, fmi, bov, 550cc evo injectors, resistor box, walbro fuel pump(not installed yet), fpr, GReddy electronic boost controller(not wired in yet), Speed factory 4bar map sensor, stage 3 clutch, arp headstuds.
I am now swallowing my pride and asking for help.
can anyone help?
Thanks in advance.
Steve
2 answers to this question
