Dexter Posted November 23, 2019 Share Posted November 23, 2019 Aerodeck VTi abs not working. When breaking hard, instead of applying abs the pedal suddenly goes in deeper and locks the brakes. No abs light, no fault codes. No fluid leaks in the system. I did get the brake lines replaced last spring, so might have something to do with the issue. I've checked the lines and made sure everything has been done properly and every line goes where they are supposed to. Any idea what might cause the abs system to malfunction, without turning on the abs light? Quote Link to comment Share on other sites More sharing options...
noodels Posted November 23, 2019 Share Posted November 23, 2019 wheel bearing ? Quote Link to comment Share on other sites More sharing options...
Dexter Posted November 24, 2019 Author Share Posted November 24, 2019 11 hours ago, noodels said: wheel bearing ? Can a worn bearing affect abs on all wheels? Last time i had to have one replaced abs was working fine. And i haven't noticed any noise but might as well give all corners a little shake next time i get the deck on a lift. Quote Link to comment Share on other sites More sharing options...
noodels Posted November 26, 2019 Share Posted November 26, 2019 Just re read,not all wheels,mine seems to lock l/h/f. no abs as one sensor on rear has failed on rear.my rhf bearing has gone. its on the list to do.. Quote Link to comment Share on other sites More sharing options...
noodels Posted January 12, 2020 Share Posted January 12, 2020 Done my wheel bearing today, equal stopping power on fronts with no locking up of one wheel only, &unsorn it this eve, it sure drives better 1 Quote Link to comment Share on other sites More sharing options...
Dave Posted January 13, 2020 Share Posted January 13, 2020 Here Andrew, have you still got your Aerodeck or was this on the S2K? Know you had your MC2 up for sale a while ago but never knew if you'd sold it or kept it? Just shows the effect a doggy wheel bearing can have eh! Quote Link to comment Share on other sites More sharing options...
noodels Posted January 15, 2020 Share Posted January 15, 2020 On the MC2 Dave 1 Quote Link to comment Share on other sites More sharing options...
Dave Posted January 15, 2020 Share Posted January 15, 2020 1 hour ago, noodels said: On the MC2 Dave Niiice! Glad you still have her mate Quote Link to comment Share on other sites More sharing options...
Dexter Posted March 28, 2020 Author Share Posted March 28, 2020 Update: this winter i've noticed that on very slippery conditions and on slow speeds, the abs works intermittently. Let's say i'm going down a icy road at 40km/h (25mph), jam the breaks, and the abs will go on and off multiple times during the duration of the braking. So kind of works but... lacks power? Could it be the abs pump on its way out? Quote Link to comment Share on other sites More sharing options...
Dave Posted March 29, 2020 Share Posted March 29, 2020 15 hours ago, Dexter said: Update: this winter i've noticed that on very slippery conditions and on slow speeds, the abs works intermittently. Let's say i'm going down a icy road at 40km/h (25mph), jam the breaks, and the abs will go on and off multiple times during the duration of the braking. So kind of works but... lacks power? Could it be the abs pump on its way out? TBH mate, mine on Ruby was the same. If it was a really icy bit of road, even doing 10mph the abs would go like crazy but the car would still be going forwards. ABS is crap on icy or really slippy roads. Quote Link to comment Share on other sites More sharing options...
