  • 0
Koni shocks + eibach pro kit springs
As title says i installed koni + eibach suspension and have 15" wheels with 195/50 pneu, the inner side of pneu is grinding with body when rotating wheels when stationary , anyone can help with this ? Thanks
Link to post
  • 0
5 hours ago, noodels said:
Oh its catching there,you need adjustable camber arms,a wheel spacer would make it worse.
or raise car a little
Think that he's showing how much space he has there to see if a spacer would be okay, but that it's rubbing on the inner side.
Either way, looks tight there as well.
Link to post
  • 0
9 hours ago, dr_broon said:
I would check again when you have the wheels turned so the way to the right - that's when mine catches the wing / arch liner.
Yep thats it, inner side of tire is catching and is worn out, will try 1cm spacer for start , should be enough .
Link to post
  • 0
Yep just as dr. said , sorry for confusion noodels :D and I cant lift it anymore , its on highest setting possible with Koni shocks unfortunatelly
Link to post
  • 0
Fully turned , first picture is place where it catch inner side of tires
Link to post
  • 0
Solved with custom made 1cm washers on shocks  , thanks for inputs guys tclosed.gif1
Link to post
  • 0
Good stuff mate. Have you got any pics? I've got a similar problem to solve.
Link to post
  • 0
Washers made from aluminium 12mm height (2mm inner slot for C cotter pin on shock, because safety :-D) , front is now with same height as rear and without problems
Link to post
  • 0
Ah, that's similar to what I had on my konis. Nice one.
Won't work with the standard style shock I've got now though. Cheers for sharing bud.
Link to post
  • 0
Yep, standart style shocks have welded lower position unfortunately :|
Link to post
Answer this question...
