This has just happened to me. Driver's side has snapped, looks like at the damper (apparently goes rusty under them and cant be seen, and is a well known issue according to the recovery man)
Found this post on the subject (link below)
Looked up J&R looks like they still do them for the car. There are 3 available, 2 outers and an inner, obvsly need to replace the snapped OS one but I guess would be sensible to do the other (near) side too asap as clearly this is a weak spot and is an accident waiting to happen. do i need to do inner as well though ? for now though just want to get her running again to see if anything else has broken. shouldnt have done as it happened at low speed / moving off. and can select gears ok still.
Cheers for any advice from others that may have suffered the same. It seems like it's a common issue though ?
Old post I know but any update on this - I have just got an issue that the recovery driver reports as being snapped driveshaft, sounds like this damper could be the problem ? will inspect and have a look under in the light hopefully tomorrow. Just been on to J&R looks like still available, 3 parts available, inner and 2 outers, should/ do I need to replace all 3 ? is the damper just on the outers ?
I'll probably do a new post tomorrow with more info
mc2hammer
6 answers to this question
