dj jordy b Posted July 21, 2010 Share Posted July 21, 2010 hi anyone had a problem with this, my vti leaking above passenger sun visor above pillar? could it be my sunroof drain? Link to comment Share on other sites More sharing options...
james Posted July 21, 2010 Share Posted July 21, 2010 yes it could be maby the drain pipe gose through therepull down the head liner Link to comment Share on other sites More sharing options...
civicturbo79 Posted July 21, 2010 Share Posted July 21, 2010 2nd that the sun roof drain tubes come from the corners of the sunroof and down the pillers into the sills if the pipe is blocked the water can leak out of the tube and give you water in the car . Rich. Link to comment Share on other sites More sharing options...
dj jordy b Posted July 22, 2010 Author Share Posted July 22, 2010 cheers lads will get a look asap Link to comment Share on other sites More sharing options...
KiNK43 Posted October 15, 2010 Share Posted October 15, 2010 hey did you get this sorted?? i have same problem. water top of a pillar.i pulled trim and lining down cant find where its coming from though. Link to comment Share on other sites More sharing options...
jalesi2001 Posted November 11, 2010 Share Posted November 11, 2010 Its normally the sunroof drain tubes as been said already, or the windscreen seal at the top. Mine was leaking when I first got her, a bit of silican sealant and its been ok so far!! Link to comment Share on other sites More sharing options...
Gav_ek4 Posted January 1, 2011 Share Posted January 1, 2011 mine has this problem, uzy had a new screen fitted just before i bought the cr so assumed it was the screen...will be checking this now jalesi -what bit of your screen was leaking and how did you seal it...was it ordinary silyc**t or sikaflex? Link to comment Share on other sites More sharing options...
simpo Posted January 5, 2011 Share Posted January 5, 2011 wat about aerial? Link to comment Share on other sites More sharing options...
BLouro Posted January 7, 2011 Share Posted January 7, 2011 water a big problem to any car, first it comes water, then you get foggy inside the car ( and not by drinking tea with your miss inside the the car ), then the roof starts to unglue, bad smell and you get a lot off work to do and money to speend...i hate car's that are aquarium's... mine had the same problem but from the heather and in the rear head lamp, the water was filling the spare tire comparment.Bruno Link to comment Share on other sites More sharing options...
KiNK43 Posted January 7, 2011 Share Posted January 7, 2011 i know, its getting on my nerves.still cant find where water is coming in on mine.ive cleaned out sunroof drains.black silicone around windscreen,and chercked door.... Still leaks! starting to smell Link to comment Share on other sites More sharing options...
