noodels Posted September 7, 2011 Share Posted September 7, 2011 maybe your petrol vac is faulty, was there pressure on release of filler cap? Link to comment Share on other sites More sharing options...
prezes Posted September 7, 2011 Author Share Posted September 7, 2011 It seems like there is pressure when I open the cap... Ill check again after work... Drives me mad this... fuel injectors? fuel pressure reg? DAMN! Link to comment Share on other sites More sharing options...
noodels Posted September 7, 2011 Share Posted September 7, 2011 if i had another dizzy mate would tend to swap, to illiminate that area!!??But you prob have !!!! Link to comment Share on other sites More sharing options...
DAVEMB2 Posted September 7, 2011 Share Posted September 7, 2011 Link to comment Share on other sites More sharing options...
simpo Posted September 7, 2011 Share Posted September 7, 2011 o2 sensor f**ked? forget that i see you have a new one Link to comment Share on other sites More sharing options...
scottravenhill Posted September 7, 2011 Share Posted September 7, 2011 Does it still run sweet with that error? Link to comment Share on other sites More sharing options...
prezes Posted September 7, 2011 Author Share Posted September 7, 2011 i have checked the dizzy, well sort of. The plug leads have good spark, there is good spark from the coil ... I have replaced the fuel filter and this bloody ... is now leaking underneath. I could not get the tiny washer that goes to the bottom line on as it kept falling off, there's no way to hold it and screw this crap on. Im fuming.Scott:Well it still can hesitate for a second from time to time between 2 and 3 k. Link to comment Share on other sites More sharing options...
prezes Posted September 7, 2011 Author Share Posted September 7, 2011 Ok I found out the the tiny washer shouldnt be there anyway. Its for a different model. So why the ... is it leaking? Link to comment Share on other sites More sharing options...
noodels Posted September 7, 2011 Share Posted September 7, 2011 should have some sort of washer on !!to seal it.one either side of the union if its one like that.. Link to comment Share on other sites More sharing options...
prezes Posted September 7, 2011 Author Share Posted September 7, 2011 The two washers go on the top bolt but its leaking on the bottom... Link to comment Share on other sites More sharing options...
