noodels Posted September 29, 2011 Share Posted September 29, 2011 Yes its a filter not cone, The ITR airbox has the K&N filter inside ,again in the picture i added.£65 newa cylinder is better than panel Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2011 Share Posted September 30, 2011 OK understood thanks i think i should have gone to bed before i posted that was soooooo knackered. Link to comment Share on other sites More sharing options...
farmerjoe Posted December 12, 2011 Share Posted December 12, 2011 k&N panel filter in the original air box is just right for a near standard car. remove the resonator and you can have some growl too. Thats the set up in my deck.On my old crx which wasnt standard and needed to breathe a lot better...i`m not convinced by the expensive pipework and huge prices. I bought a cheapie used induction kit- kept the pipework and the silicon adaptors, but binned the cheap filter.I got a good filter, then i popped to b&Q for some silver air insulated reflective tape, i wrapped the intake in that to reflect heat from the engine and bobs your uncle, my B20 went even better on my butt dyno.What is the resonator and how would i remove it? Link to comment Share on other sites More sharing options...
NIKH25 Posted December 12, 2011 Share Posted December 12, 2011 http://www.civic5.com/forum/viewtopic.php?f=86&t=995Resonator box is part of the induction system helping feed air to the intake and supress the noise. Link to comment Share on other sites More sharing options...
civicnut1977 Posted May 23, 2012 Share Posted May 23, 2012 i know obviously i dont have my honda as yet but i know quite alot of the cold air feed process as when i had my 2.0 16v redtop xe engine i spent month after month to see which gave out the best performance as obviously the hot air is the problem , i even had a nice trick in my original airbox where i located a K&N conefilter and a 100mm cold air feed induction pipe.On the calibra's its located on the tow hook flip down panel and secures to the bottom of the airbox but if theres floods etc , it would be a case of stopping slip it out of the paneel and reroute the cold air feed tube further up so no water damage would result.very good guide , i would think i would opt for either the ITR replacement airbox or the cold air feed with the short ram . Link to comment Share on other sites More sharing options...
noodels Posted May 23, 2012 Share Posted May 23, 2012 ^^^thats what i got one on ek9 atm £50 inc PP with rez and filter but no pipe Link to comment Share on other sites More sharing options...
civicnut1977 Posted May 24, 2012 Share Posted May 24, 2012 ok well iguess i will have to wait and see what intake mods i do to mine when i get it. Link to comment Share on other sites More sharing options...
S4DAM Posted June 10, 2012 Share Posted June 10, 2012 http://www.toyosports.co.uk/94-01-honda-integra-dohc-sohc-air-induction-kit-2799-380-p.aspgreat buy at 27.99, does anyone know if the integra short arm air intakes wud b the same as the civic vti ones?had one on from here on my old accord, great sound in vtec, real screamer Link to comment Share on other sites More sharing options...
noodels Posted June 10, 2012 Share Posted June 10, 2012 viewtopic.php?f=141&t=10189 Link to comment Share on other sites More sharing options...
civicnut1977 Posted June 11, 2012 Share Posted June 11, 2012 do you guys have a quick method of rerouting your tube if in the event of a massice flood , as with my air intake i can pull down the tow hook cover panel and push the cold air feed pipe to the left and aim the the hose upwards as my bumper is quite low down lol ( a mate of mine attempted to drive his v6 in a flood and blew a hole in the side of the engine Note that was a tumble dryer hose i first used and then realised she sucked like a bitch lol so then i got a 86mm professional black hose and worked a treat Link to comment Share on other sites More sharing options...
