civicturbo79 Posted February 15, 2011 Share Posted February 15, 2011 Its hard to say ,i would fit a light to the solenoid feed and see it the solenoid is getting power when you are driving . Rich. Link to comment Share on other sites More sharing options...
shebabby Posted February 16, 2011 Author Share Posted February 16, 2011 Its hard to say ,i would fit a light to the solenoid feed and see it the solenoid is getting power when you are driving . Rich.if there is a feed wen im driving wot could it be ?at the min its like wen you turn a tap on slowly ? there doesnt seem to be a cross over like before its more ov a fade into the vtec !! Link to comment Share on other sites More sharing options...
johngreen537 Posted February 16, 2011 Share Posted February 16, 2011 Have a look in the how to section mate, there's one in there fro vtec indicator light.What doing this will tell you is when the vtec is on and off, so if the electrical signal from solenoid is telling the ECU that VTEC should engage, the light will come on. Should take no time at all for the VTEC 'mechanical' stuff to operate after the ECU gives the signal!So if you wire in indicator light, then there is a big delay in the VTEC light coming on and the feeling of vtec, then it's more likely to be mechanical! if the light flickers on off etc, then it's more likely electrical / sensor / actuator based. Link to comment Share on other sites More sharing options...
shebabby Posted February 17, 2011 Author Share Posted February 17, 2011 hi iv fitted a vtec light it comes on at 5000 rpm but still doesnt feel like the vtec is kicking in like it use to ?the vtec is working but not a kick more ov a build up . seems to be a bit better since iv cleand the filter ? Link to comment Share on other sites More sharing options...
jalesi2001 Posted February 17, 2011 Share Posted February 17, 2011 Adjusted the valve clearences recently? Link to comment Share on other sites More sharing options...
jonnyricer Posted February 17, 2011 Share Posted February 17, 2011 JaLe s when should the valve clearances be done?? Link to comment Share on other sites More sharing options...
johngreen537 Posted February 18, 2011 Share Posted February 18, 2011 Every other month on my car If your engine sounds 'tappety' or ticky then you need to do them!Only takes an hour and difference is cracking! Link to comment Share on other sites More sharing options...
knight Posted February 18, 2011 Share Posted February 18, 2011 Every other month on my car If your engine sounds 'tappety' or ticky then you need to do them!Only takes an hour and difference is cracking!What you can do it yourself can you??? Link to comment Share on other sites More sharing options...
shebabby Posted February 18, 2011 Author Share Posted February 18, 2011 Adjusted the valve clearences recently? thats on my next to do list owned the car for roughly 6 years and never been adjusted but she doesnt tap or tick Link to comment Share on other sites More sharing options...
shebabby Posted February 19, 2011 Author Share Posted February 19, 2011 ok been out tonight in the deck took her for a long run and it seems the vtec is coming in with alot more power than before but still not a kick like it should . think next will be the valve clearence ! Link to comment Share on other sites More sharing options...
