ryan.. Posted April 10, 2011 Share Posted April 10, 2011 Is there an easy way to do this in a vti/vti-s?Me and a couple mates did an oil change, plugs and oil filter change today and getting the filter off was a knightmare. We ended up punching a hole in it with a screwdriver moving it slightly, making another hole, move a bit more etc etc till it was loose enough to undo by hand. There wasnt enough room to put in a proper removal tool....how do you guys do it? Link to comment Share on other sites More sharing options...
southwestmb6 Posted April 10, 2011 Share Posted April 10, 2011 i use a special tool from snap on . Its the same size as the oil filter itself and fits on ratchet with extension bar . I have also done the same way as u m8 . And yes its a pain this way. Link to comment Share on other sites More sharing options...
james Posted April 10, 2011 Share Posted April 10, 2011 i sued a ratchet and bike chain hybird diy oh and some sandpaper ... good grip i realy hate rembering this Link to comment Share on other sites More sharing options...
KiNK43 Posted April 11, 2011 Share Posted April 11, 2011 I use a pair of large grips. Squashes the old filter but ok.Then I just tighten the new one as much as I can by hand. I have got hulk hands tho. No problems at all with leaks or coming loose Link to comment Share on other sites More sharing options...
ryan.. Posted April 11, 2011 Author Share Posted April 11, 2011 you're supposed to only hand tight the new filter anyway so doing it up isnt a problem. I tried some large grips but couldnt get them in place due to the lack of room Link to comment Share on other sites More sharing options...
johngreen537 Posted April 11, 2011 Share Posted April 11, 2011 Yup. Pain in the arse! I found, get some marigolds, pour very cheap lemonade on them (outside of them obviosuly), let them dry out and they should be sticky as hell! Getting it off it much easier under the car, as you can reach up and grip it properly, just be prepared to be covered Many many times though, I've used a long screwdriver and rammed it through! Filter wrenches ETC are crap as there's so little room to manouver in the back of there! Snap on one is bloody good, but personally, for the ammount of times you'd use it at home, not worth the cost! Link to comment Share on other sites More sharing options...
ryan.. Posted April 11, 2011 Author Share Posted April 11, 2011 i did notice the old filter was not as tall as the new one so fingers crossed next time i change it access will be a tiny bit easier. hen trying to turn the old one my thumb was fouling on the engine mount Link to comment Share on other sites More sharing options...
johngreen537 Posted April 12, 2011 Share Posted April 12, 2011 lol, usually people just put them on too tight mate! and forget to use new engine oil around the rubber seal!They only supposed to be hand tight, but I've seen people using filter wrenches to tighten them up too! :S Link to comment Share on other sites More sharing options...
15vtec-e Posted April 12, 2011 Share Posted April 12, 2011 Totaly agree it is the faffiest filter to change in 35 years of motoring I use the original cheapo bike chain and wrench, setting the size beforehand and locking it with a twisted piece of wire on the wrench. Put a dab of oil on the oil seal rubber before hand tightening the new filter ...Pete Link to comment Share on other sites More sharing options...
beastgtir Posted April 12, 2011 Share Posted April 12, 2011 get one of these buddy, they are about £10 delivered off ebay for honda fitment ones. piece of doddle. Link to comment Share on other sites More sharing options...
