jalesi2001 Posted September 16, 2009 Share Posted September 16, 2009 Looking sweet bud, love build threads like this!! Its great to see something different!!! Quote Link to comment Share on other sites More sharing options...
FREAKBOY Posted September 19, 2009 Author Share Posted September 19, 2009 I added more text and have questions, help is needed now. Suggestions please Quote Link to comment Share on other sites More sharing options...
civicturbo79 Posted September 19, 2009 Share Posted September 19, 2009 You waste gate spring sets the boost pressure . the waste gate comes with a 3 psi spring in there . you can do two things . buy the psi spring you want and fit it or fit a bleed valve . to do this fit the valve in the vacuum pipe that runs to the waste gate the more you wind it in the higher the boost . As for management i assum you need to keep that standard ecu for the auto gearbox (gearchanges) I had a greddy e-manage blue on my car right up to 379 bhp . http://cgi.ebay.co.uk/TRUST-GRreddy-Ema ... 286.c0.m14Its a piggy back ecu so you can leave the standard ecu in place for the gearbox . The standard map sensor will read boost up to 12 psi . but the ecu will put the light on a soon as it see's boost because it does not know what it is . you will need a map sensor for the e manage http://cgi.ebay.co.uk/Boost-Map-Sensor- ... 286.c0.m14You will also need a welbro 255 fuel pump . http://cgi.ebay.co.uk/WALBRO-255-FUEL-P ... 286.c0.m14 Quote Link to comment Share on other sites More sharing options...
vti4mark Posted September 19, 2009 Share Posted September 19, 2009 to anwser your question, you need to get it tuned as adding more air and not the fuel is not going to work.as for low boost could be loads off thing and as you have just built it up your going to run in to loads off little problems like this.my old erst was an arse when i rebuilt that spent near £4k on the engine on all the right bits to make it 300bhp safely, but it needed 8 hours off tuning and trying diffrent maps to get it right .hang in there, get it mapped, then enjoy driving it. Quote Link to comment Share on other sites More sharing options...
FREAKBOY Posted September 19, 2009 Author Share Posted September 19, 2009 Thanks, the wastegate has an 8psi spring in though. I welcome your suggestion and the links. Fuel pressure was at 3.5BAR on the reg. I was just trying to see if it made boost. Quote Link to comment Share on other sites More sharing options...
civicturbo79 Posted September 19, 2009 Share Posted September 19, 2009 The fuel pressure will be fine at the min as you are not adding more fuel once you get into the map and the fueling is going up the fuel pump will not keep up ( i did this with mine ) you will need injectors as well the standard ones will not give you fueling for 10 psi . maybe 3 psi at a push. Have you got a vacuum pipe going to the waste gate ? Rich. Quote Link to comment Share on other sites More sharing options...
FREAKBOY Posted September 19, 2009 Author Share Posted September 19, 2009 Yes the vacuum signal lines all pretty much run from one manifold source. One is to the bottom port on the W/G. If I put bigger injectors in now I don't think the ECU will see them as bigger, I do plan to get some but will only go for 440cc'ish as i'm going to stay with the 8psi maximum. They are on the shopping list.Thanks Quote Link to comment Share on other sites More sharing options...
civicturbo79 Posted September 19, 2009 Share Posted September 19, 2009 you are right you cannot fit the bigger injectors till you have the managment fitted . so you can tell it what size the injectors are . if you just fit new injectors it would not run. 440 will be more the big enough. Rich. Quote Link to comment Share on other sites More sharing options...
FREAKBOY Posted September 19, 2009 Author Share Posted September 19, 2009 Cheers Rich, i'm getting something right then, I need to find someone who will socket this thing now, i'm pretty sure that it can be. I'd prefer a professional (not Bodie & Doyle) to do it. Has anyone heard of GotBoost?Andy Quote Link to comment Share on other sites More sharing options...
uzy Posted September 20, 2009 Share Posted September 20, 2009 nice work Quote Link to comment Share on other sites More sharing options...
