ryan.. Posted October 17, 2011 Share Posted October 17, 2011 Does anyone have a genuine Honda oil filter for a B18 that they can measure the diameter of?I bought a removal tool off ebay advertised as fitting the B18 but its much too small for the filter I had on there and the one I bought Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted October 17, 2011 Share Posted October 17, 2011 The last time I bought a OEM Honda filter it was smaller than my previous Honda OEM one. I asked they the guy and I'm sure he said they have changed them. Link to comment Share on other sites More sharing options...
Didjeridave Posted October 17, 2011 Share Posted October 17, 2011 Smack a screwdriver through it & hey presto you've got a handle to turn it round! Just make sure you don't go through it centrally & stick near the outermost half of the filter - you need to avoid damaging the thread that the filter screws on to which is about an inch long. And have a few rags handy. They should be on hand tight & should come off with little more than hand-tight-torque anyway. Link to comment Share on other sites More sharing options...
ryan.. Posted October 17, 2011 Author Share Posted October 17, 2011 they are on hand tight BUT the heat of the engine makes them much much tighter. I did that method last time and never again will i do that. Oil everyware and it took ages as there is no room Link to comment Share on other sites More sharing options...
Roylewaa Posted October 17, 2011 Share Posted October 17, 2011 Smack a screwdriver through it & hey presto you've got a handle to turn it round! Just make sure you don't go through it centrally & stick near the outermost half of the filter - you need to avoid damaging the thread that the filter screws on to which is about an inch long. And have a few rags handy. They should be on hand tight & should come off with little more than hand-tight-torque anyway.I found it easier if you have to drive a screwdriver through it to remove the air intake and reach down, as I found I couldn't get alot of leverage from underneath, dunno if that would work with a b series though as probably less room Link to comment Share on other sites More sharing options...
noodels Posted October 17, 2011 Share Posted October 17, 2011 i got one of thesehttp://www.ebay.co.uk/itm/DRAPER-77592- ... 4840ecb58d Link to comment Share on other sites More sharing options...
ryan.. Posted October 18, 2011 Author Share Posted October 18, 2011 thats what i ended up buying from a local motor factors. Its usless imo Link to comment Share on other sites More sharing options...
noodels Posted October 18, 2011 Share Posted October 18, 2011 not that good,, good job dont have to change filters with them all day long Link to comment Share on other sites More sharing options...
james Posted October 18, 2011 Share Posted October 18, 2011 thats what i ended up buying from a local motor factors. Its usless imoput on the chain strap and put a screwdriver or nail trough the holes in the chain for extra bight Link to comment Share on other sites More sharing options...
simpo Posted October 18, 2011 Share Posted October 18, 2011 i just use my hand and sand paper for a good grip usually works Link to comment Share on other sites More sharing options...
