My ej civic coupe
ash d-series
Just bought this a couple of weeks ago. It started life as an lsi and now has a b16a2 in it but the conversion wasn't completed properly meaning there was loads of codes in the ecu and the vtec wasn't working.
After a lot of head scratching and searching/ annoying people for info on the forums i've finally figured out the problems and am just waiting on my ecu to return from H-tune to see if i've fixed it.
Its not mint and it does need a couple of new panels which i think i've sourced.
The first thing i plan on changing is the wheels because they are way too big and they have ripped the front wing to bits.
Anyway heres the pictures
nice looking coupe mate, like the early style coupes best. Did you put the engine in or was it already in place? Lots of potential, gonna be a sweet coupe!
I bought it with the engine already in but the guy gave up on the wiring and the brakes haven't been changed with the conversion so it is kind of half finished at the moment.
I made the mistake of not asking him enough questions when i went to get it which means i have no clue what the engine originally came out of, its a strange one because it is a b16a2 but seems to be wired up like a jdm engine and turns out it had a JDM ecu in it too so after a bit of head scratching i decided to to send the ecu off to h-tune to get a custom map to get get rid of the knock sensor codes that it kept spitting out and now all i need to do is wire up the vtec and it should be good to go 'fingers crossed'
