Car cuts out after 6-8 minutes
crx92ie
Hi all,
Just wondered if anyone had come across this issue before. I have an MB2 Civic 1.4 and before Christmas it developed an odd issue. Basically the car starts and runs fine, but after about 6 or 7 minutes it will cut out. It will then turn over but it won't start for a couple of hours. After a couple of hours it will start again on the first turn and run perfectly for 6-7 minutes before cutting out again.
I'm new to the car so I didn't know how to check the error codes. I found some information about that so I'll check this evening to see if it is throwing a code. Just seeing if anyone had encountered a similar issue. I should say that I've changed the plugs and air filter, and checked oil and coolant levels and they're fine.
Suggestions welcome!
Have had the main relay issue suggested before (and I've had it in other Hondas I've owned), but it doesn't usually cause the engine to cut out, AFAIK, it just makes the car hard or impossible to start when warm.
I'll see what the ECU says later. Thanks for the suggestions so far.
