noodels Posted October 6, 2012 Share Posted October 6, 2012 good site for rotas photo shop http://www.rarerims.co.uk/virtual/ Quote Link to comment Share on other sites More sharing options...
Krzys Posted December 3, 2012 Share Posted December 3, 2012 kenny_tmt said: In the past weeks I've been searching for some new rims for my aerodeck, it is not easy to find a brand which has the right specs. I did a photoshop with the Rota spec-r rims and I like it a lot! What do you guys think ? Any ideas ? Still wanting Rota's?viewtopic.php?f=31&p=144247#p144247 Quote Link to comment Share on other sites More sharing options...
kenny_tmt Posted December 30, 2012 Author Share Posted December 30, 2012 Bought a new header today the crappy srs 4-1 header had to go , The new one is a High end performance header 2.5inch, I hope to get some good gains from it!Had a verry nice x-mas present also, Skunk2 66mm tb Quote Link to comment Share on other sites More sharing options...
knight Posted December 30, 2012 Share Posted December 30, 2012 Look very nice!!! Quote Link to comment Share on other sites More sharing options...
weetec Posted December 30, 2012 Share Posted December 30, 2012 that manifold is rude a bit of advice on that throttle body.... hold it with a light source on the opposite side.... if your able to see light through it youll hsve a problem setting the idle..... send it back .... i have experienced this myself. nightmare.. also im pretty sure the idle on these has to be custom set via remapped ecu... check this on the net!!! something to do with airflow rate and the adjuster screw for idle air mixture? safer bet is one of an integra as the air incoming spout is sized to the ITR intake pipe... again the net is your friend. if you have or gain more knowledge on this please update us........ cheers Quote Link to comment Share on other sites More sharing options...
weetec Posted December 30, 2012 Share Posted December 30, 2012 kenny_tmt said: In the past weeks I've been searching for some new rims for my aerodeck, it is not easy to find a brand which has the right specs. I did a photoshop with the Rota spec-r rims and I like it a lot! What do you guys think ? Any ideas ? the side on pic is really nice... but them wheel widths from rota are allways 7"&more and the offsets are approximately ET45/40..the result is you introduce a lot of tyretread visibility from looking at the stance from any other angle. for me that cruddy visible tread paired withfresh wwhipped tyre walls dont work.... just my 2p worth... Quote Link to comment Share on other sites More sharing options...
kenny_tmt Posted December 30, 2012 Author Share Posted December 30, 2012 weetec said: that manifold is rude a bit of advice on that throttle body.... hold it with a light source on the opposite side.... if your able to see light through it youll hsve a problem setting the idle..... send it back .... i have experienced this myself. nightmare.. also im pretty sure the idle on these has to be custom set via remapped ecu... check this on the net!!! something to do with airflow rate and the adjuster screw for idle air mixture? safer bet is one of an integra as the air incoming spout is sized to the ITR intake pipe... again the net is your friend. if you have or gain more knowledge on this please update us........ cheersThe TB is allready mounted without any problems, the aerodeck is in the garage for the ITR cams and valvetrain.. Quote Link to comment Share on other sites More sharing options...
weetec Posted December 30, 2012 Share Posted December 30, 2012 kenny_tmt said: weetec said: that manifold is rude a bit of advice on that throttle body.... hold it with a light source on the opposite side.... if your able to see light through it youll hsve a problem setting the idle..... send it back .... i have experienced this myself. nightmare.. also im pretty sure the idle on these has to be custom set via remapped ecu... check this on the net!!! something to do with airflow rate and the adjuster screw for idle air mixture? safer bet is one of an integra as the air incoming spout is sized to the ITR intake pipe... again the net is your friend. if you have or gain more knowledge on this please update us........ cheersThe TB is allready mounted without any problems, the aerodeck is in the garage for the ITR cams and valvetrain..hehe.... forgot you have all ready remapped etcetc... thought you was fresh bait... just looked at previous pages oops.... Quote Link to comment Share on other sites More sharing options...
noodels Posted December 30, 2012 Share Posted December 30, 2012 thats a very loooooooooooooooong 4-2-2-1 Quote Link to comment Share on other sites More sharing options...
weetec Posted December 30, 2012 Share Posted December 30, 2012 get some new valve stem seals whilst they in there Quote Link to comment Share on other sites More sharing options...
