Kenny_tmt's Silver MC2/ Little update pg4!
kenny_tmt
  • 1 month later...
In the past weeks I've been searching for some new rims for my aerodeck, it is not easy to find a brand which has the right specs. I did a photoshop with the Rota spec-r rims and I like it a lot! What do you guys think ? Any ideas ?
Still wanting Rota's?
viewtopic.php?f=31&p=144247#p144247
  • 4 weeks later...
that manifold is rude [smitten.gif] a bit of advice on that throttle body.... hold it with a light source on the opposite side.... if your able to see light through it youll hsve a problem setting the idle..... send it back .... i have experienced this myself. nightmare.. also im pretty sure the idle on these has to be custom set via remapped ecu... check this on the net!!! something to do with airflow rate and the adjuster screw for idle air mixture? safer bet is one of an integra as the air incoming spout is sized to the ITR intake pipe... again the net is your friend. if you have or gain more knowledge on this please update us........ cheers
the side on pic is really nice... but them wheel widths from rota are allways 7"&more and the offsets are approximately ET45/40..the result is you introduce a lot of tyretread visibility from looking at the stance from any other angle. for me that cruddy visible tread paired withfresh wwhipped tyre walls dont work.... just my 2p worth...
The TB is allready mounted without any problems, the aerodeck is in the garage for the ITR cams and valvetrain..
hehe.... forgot you have all ready remapped etcetc... thought you was fresh bait... just looked at previous pages oops.... :)
