dinochips Posted May 8, 2013 Share Posted May 8, 2013 Looks like you have put alot of effort into this car. keep it up dude Quote Link to comment Share on other sites More sharing options...
Guest craigblight Posted May 8, 2013 Share Posted May 8, 2013 dinochips said: Looks like you have put alot of effort into this car. keep it up dude yep i have and not finished yet Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted May 8, 2013 Share Posted May 8, 2013 She is looking fine fine fine... Great work there fella only thing im not sure about is the underside of the bonnet but who is going to see it very often and as we all know You can please some of the people some of the time but you can't please all of the people all of the time keep up the top work mate will be checking back here regularly to see your progress Quote Link to comment Share on other sites More sharing options...
Guest craigblight Posted May 8, 2013 Share Posted May 8, 2013 Mr Brown said: She is looking fine fine fine... Great work there fella only thing im not sure about is the underside of the bonnet but who is going to see it very often and as we all know You can please some of the people some of the time but you can't please all of the people all of the time keep up the top work mate will be checking back here regularly to see your progress cheers dude hopefully get sum more money and do more to it Quote Link to comment Share on other sites More sharing options...
marko Posted May 8, 2013 Share Posted May 8, 2013 wow! are you guys on crack? no amount of polishing will sort that roof out, you need to sand that right back with 80 grit then a 240/320 grit re-prime then dust over some satin/matt black when i say dust i mean dust, then set at it with a WET 800 grit and a block the matt black you dusted on will stick in any low spots or any scratches so you can see whenn its super smoothe then give it a wash, good wipe with a degreaser we called it panel wipe others call it soft spirt wipe mask it up throw your base coat on in 3 even coats, if your using a rattle can get yourself a 1K laquer and give it a couple of dusty dry coats then finish of with a couple of nice wet coats. give it around 3-7 days for it to fully cure and set then give it a wet flat with 2000 grit sandpaper then a polish and a wax it will look more like glass than your windows i promise Quote Link to comment Share on other sites More sharing options...
Guest craigblight Posted May 8, 2013 Share Posted May 8, 2013 marko said: wow! are you guys on crack? no amount of polishing will sort that roof out, you need to sand that right back with 80 grit then a 240/320 grit re-prime then dust over some satin/matt black when i say dust i mean dust, then set at it with a WET 800 grit and a block the matt black you dusted on will stick in any low spots or any scratches so you can see whenn its super smoothe then give it a wash, good wipe with a degreaser we called it panel wipe others call it soft spirt wipe mask it up throw your base coat on in 3 even coats, if your using a rattle can get yourself a 1K laquer and give it a couple of dusty dry coats then finish of with a couple of nice wet coats. give it around 3-7 days for it to fully cure and set then give it a wet flat with 2000 grit sandpaper then a polish and a wax it will look more like glass than your windows i promise cheers for the advist will have a go when have little more time Quote Link to comment Share on other sites More sharing options...
marko Posted May 8, 2013 Share Posted May 8, 2013 craigblight said: marko said: wow! are you guys on crack? no amount of polishing will sort that roof out, you need to sand that right back with 80 grit then a 240/320 grit re-prime then dust over some satin/matt black when i say dust i mean dust, then set at it with a WET 800 grit and a block the matt black you dusted on will stick in any low spots or any scratches so you can see whenn its super smoothe then give it a wash, good wipe with a degreaser we called it panel wipe others call it soft spirt wipe mask it up throw your base coat on in 3 even coats, if your using a rattle can get yourself a 1K laquer and give it a couple of dusty dry coats then finish of with a couple of nice wet coats. give it around 3-7 days for it to fully cure and set then give it a wet flat with 2000 grit sandpaper then a polish and a wax it will look more like glass than your windows i promise cheers for the advist will have a go when have little more timethanks for not taking it the wrong way Quote Link to comment Share on other sites More sharing options...
Guest craigblight Posted May 8, 2013 Share Posted May 8, 2013 marko said: craigblight said: marko said: wow! are you guys on crack? no amount of polishing will sort that roof out, you need to sand that right back with 80 grit then a 240/320 grit re-prime then dust over some satin/matt black when i say dust i mean dust, then set at it with a WET 800 grit and a block the matt black you dusted on will stick in any low spots or any scratches so you can see whenn its super smoothe then give it a wash, good wipe with a degreaser we called it panel wipe others call it soft spirt wipe mask it up throw your base coat on in 3 even coats, if your using a rattle can get yourself a 1K laquer and give it a couple of dusty dry coats then finish of with a couple of nice wet coats. give it around 3-7 days for it to fully cure and set then give it a wet flat with 2000 grit sandpaper then a polish and a wax it will look more like glass than your windows i promise cheers for the advist will have a go when have little more timethanks for not taking it the wrong way it ok dude Quote Link to comment Share on other sites More sharing options...
Maxposer Posted May 8, 2013 Share Posted May 8, 2013 craigblight said: just looked on civiclife and they have said my car is s**t. owell i love hatersyour car mate.....who cares what anyone else thinks...no one person is the same matey and if u like it F@@k dem lol keep up the mods mate Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted May 8, 2013 Share Posted May 8, 2013 craigblight said: just looked on civiclife and they have said my car is s**t. owell i love hatersI have noticed there are a few dis-respectful people on that site... I started a thread and post some pics of my MB3 when she was standard. Their comments were "sell it and buy a real Civic, its a oldmans car, its a Rover" and apparently I fail at life... Quote Link to comment Share on other sites More sharing options...
