my ma8 civic (lots of updates)
Guest craigblight
Guest craigblight
Yeah I've got sunroof on mine.
Took me about half an hour to find everything that needed undoing to remove.
Summary to unbolt/unscrew is:
Visors.
grab handles.
Interior light.
Plastic clips above back seats.
A Pillars pull off as they are only clipped in, I cheated with B and C pillars, just pulled them enough to free the headlining but you can remove these if you want but will be more work.
Sunroof surround pulls off.
You'll need to pull down the door seals too!
Then the headlining will come out through the tail gate.
Hope that gives you a better idea mate!
does the sunroof sheild come off then to so can wrap that
You'll have to remove the glass to get that out, instructions for that are in the manual you can download from the tabs at the top. Headlining has to come out first I think but I haven't done it myself so I can't be much help there.
Guest craigblight
i just do it while on car
