Nathan91 Posted December 22, 2012 Share Posted December 22, 2012 I have a mb2 an im lookin to carbon wrap the pillar plastics on the outside - but i wanna tek em off n do a proper job. Do they jus pop off or is there a special way to do it? Btw im talkin about the black things between the windows lol Quote Link to comment Share on other sites More sharing options...
hickster Posted December 22, 2012 Share Posted December 22, 2012 I think from memory there is a hole on the inside that lets you pop the clip with the end of a screwdriver, been a while since I had them off though. Have a good look around the door I'm pretty sure you don't have to lever them from the outside. Quote Link to comment Share on other sites More sharing options...
simpo Posted December 23, 2012 Share Posted December 23, 2012 I thought there was a couple screws on the inside? Quote Link to comment Share on other sites More sharing options...
ryan.. Posted December 23, 2012 Share Posted December 23, 2012 im pretty sure they just pop off Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted December 23, 2012 Share Posted December 23, 2012 yeh i think there are some screws on the inside and some stupid clips to try and unclip without breaking aswell, i failed trying to take mine off! Quote Link to comment Share on other sites More sharing options...
Nathan91 Posted December 23, 2012 Author Share Posted December 23, 2012 Jus done 1 side looks pretty good if i say so ma sen lool - theres 3 screws inside an 2 clips - also iv jus discoverd ma car has sprung a leek or 2 - the spare wheel well is more like a miniture pond an both footwells on the passinger side ( front and back) are wetter than the actual floor outside - any1 else had a problem like this ?? Any ideas what it cud b?? Rusted thru?? Weak points?? Help please Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted December 23, 2012 Share Posted December 23, 2012 Jus done 1 side looks pretty good if i say so ma sen lool - theres 3 screws inside an 2 clips - also iv jus discoverd ma car has sprung a leek or 2 - the spare wheel well is more like a miniture pond an both footwells on the passinger side ( front and back) are wetter than the actual floor outside - any1 else had a problem like this ?? Any ideas what it cud b?? Rusted thru?? Weak points?? Help pleaseSunroof?but the boot is wet aswell maybe boot seal and water running into boot and into rear floorwell then traveling to front floorwell Just a guess really Quote Link to comment Share on other sites More sharing options...
ryan.. Posted December 23, 2012 Share Posted December 23, 2012 boot could be the rear vents below/behind the bumper Quote Link to comment Share on other sites More sharing options...
hickster Posted December 23, 2012 Share Posted December 23, 2012 Sunroof drains- there are two leaky rear ones as well as the two that go to the front wings; they all suck balls. Also check tailgate seal and rear light cluster seal. If your headlining is wet the front gutter seals (against the windscreen) also may be suspect. Quote Link to comment Share on other sites More sharing options...
Nathan91 Posted December 23, 2012 Author Share Posted December 23, 2012 I dont av a sunroof - im not tht lucky lol - and iv only jus noticed the footwells 2day - ill investgate in ma dinner time 2mora - cheers guys Quote Link to comment Share on other sites More sharing options...
