Re: KNK Project. photowhorish!
KiNK43
yes im regularly looking at how to's and manuals etc. slowly, now as i look at the box sitting there i think ahh only a few nuts n bolts to do up. so i think im ready! haha.
can see it now first drive, torque steer into a bush. keep being told im stupid for ditching the lsd.
but im not convinced. think it should benefit nicely from the shorter ratios.
i get the feeling it wont be as tight on the front with out an lsd
  • Replies 904
Tight? U ever drove an m? Haha.
I never feel in control as it is. Well skitchey since I changed the wheels. Well however it feels its going on for a while. Then I can think about reconditioning the s9b. Or even pinching the lsd out of it. We'll see.
  • 2 weeks later...
what a day, got down to fitting decat. had to give up. bolts so rusted on cant shift em!!!!
very annoying.
noticed while i was under there that front arb link has snapped clean off. job for tomorow i think.
not exactly helping the cornering im sure!
  • 2 weeks later...
4kg flywheel and f1 stage 3 clutch arrived today so just need to clean up the box and change the seals and good to go. Still not made up my mind if im biting off more than I can chew. Might save and have fitted properly. Just skint.
Very excited though. Cant wait to give the old girl some more life!
It would be intresting to see what its like without the LSD from a launch. Also to see what its like to go around a corner quite fast. You will have to report back once its in!
I have a S80 sat around that will be fitted shortly so will have the same ratios, i cant wait to see if the difference is as big as everyone says it is. I will update my thread once its done.
when i first got my car the diff was noisy so sent the box off to a repairer and got box put back in. now at the time i thought to myself this isnt as fast as it was before the repair. is it possible they just removed the lsd?
if they have then the torque steer aint that bad, plus my steering wheel is off centre so would imagine its fine if the wheel is straight, thats IF they did remove lsd
Imagine noisy diff, they just replace the bearings.
What was the cost of repair out of interest. Wouldnt mind getting the s9b repaired, noisy input bearing.
