Re: KNK Project. photowhorish!
KiNK43
  • Replies 904
Did you glue the carbon to the back of the bits to help secure it?
I most certainly did. Bit of superglue under the awkward angles. Can't believe you giving away the tricks of the trade. :D
Ummmmmm Tein super streets drool.gif1drool.gif1 drool.
gif1 Nice!!! 8-)8-)8-)
Hope they ok. Not having much luck lately.
They are eg/ek. At least that's what I've been told.
They are fork type at the rear. Looks wider than our MB, so maybe need spacers or new lca?
Other than that. 32 step damper adjust and ride height adjust.
32 step damper adjustment :o They sound like the real deal mate !! You must be very happy! :)
well these are the actual ones i have baught. like i said they are a bit flaky etc.
chap said they have done about 10k on a daily drive car. no leaks. no knocks. no clicks..
all good!
also today i made myself some new earth leads out 25mm² 300amp braided welding cable. gonna have a blue theme with ht leads etc i think.
looking good mate 8-)
add more earths if you can it will make it run smoother and enhance the spark to the plugs ;)
Suppose that makes sense. So shall I just put them all over the place from engine to the engine bay?
ye mate :)
but try to keep them short
and a good thickness aswel !
i used audio amp cable it works a treat ;) but dont forget if its a flowing cable you will need to have the flow going both ways :?:
unless your just adding earths .
iv platted a few earths together so i didnt have wires allover :idea: so each earth lead i added is a three core 8-)
check out my thread below :D
