My MB6 from Barcelona
David gp
  • 3 weeks later...
I think I found the source of the problem. The right rear wheel is more advanced than the other side, but do not know which of the two is affected. I have heard that on some cars you can regulate the advance (so I do not know if you say in English), but that does not find a way. Do you know if there is any way to adjust it? I found a Toe regulators on eBay but do not know if they do something ...
The problem is how to find which one is affected. Can not be any other arm of the rear suspension?
Just do both sides, you can't go wrong then! Plus when it comes to suspension if you replace one, you'll end up doing the other shortly after anyway! :idea:
