Dexter Posted January 2, 2014 Share Posted January 2, 2014 I'm changing my plugs tomorrow, and started thinking if i should also replace my dizzy cap and rotor, and maybe even leads at the same time. Should you replace them at certain intervals, or only if they start looking worn or cracked or eroded etc.? I've had my MC2 for almost 5 years and only replaced the plugs twice so far. The car runs fine. Quote Link to comment Share on other sites More sharing options...
simpo Posted January 2, 2014 Share Posted January 2, 2014 If you have never changed the cap and leads then I would do them! And the rotor arm while ur there Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted January 2, 2014 Share Posted January 2, 2014 If you have never changed the cap and leads then I would do them! And the rotor arm while ur there x2. Quote Link to comment Share on other sites More sharing options...
Dexter Posted January 2, 2014 Author Share Posted January 2, 2014 All right will do. Genuine honda parts for the cap and rotor + perhaps Magnecor KV85 leads to add a bit of upgrade? Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted January 2, 2014 Share Posted January 2, 2014 Sounds good to me, denso iridium plugs? Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted January 2, 2014 Share Posted January 2, 2014 I've never done mine :-s About time you did then. Quote Link to comment Share on other sites More sharing options...
Dexter Posted January 3, 2014 Author Share Posted January 3, 2014 Sounds good to me, denso iridium plugs? NGK Iridium IX Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted January 3, 2014 Share Posted January 3, 2014 NGK Iridium IX That works. Quote Link to comment Share on other sites More sharing options...
beastgtir Posted January 3, 2014 Share Posted January 3, 2014 Why iridium? I prefer a good platinum tip spark plug.A lot cheaper and you can change them more often. Around £10-15 per set. 1 Quote Link to comment Share on other sites More sharing options...
