KiNK43 Posted May 15, 2014 Share Posted May 15, 2014 That's normal mate I'm sure. I have same hole thought looked weird so photographed it.. Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted May 15, 2014 Share Posted May 15, 2014 This is turning out to be a right nightmare for you, I hope you can find the problem without having to buy another car. Quote Link to comment Share on other sites More sharing options...
10000rpm Posted May 15, 2014 Share Posted May 15, 2014 Yeah these were all changed. I'd have thought that when the plugs are tightened that no oil would get past. Had that problem with a zetec engine in a escort I had. Only puffed smoke if I removed the plugs and some oil went in the bores,this is smoking all the time ATM Been looking at replacement engines but people tend to sell the whole conversion for good money. Probably cheaper buying another car lolIf your spark plug ceramics(white bit) are dry then the spark plug gaskets on the rocker are not the problem. Quote Link to comment Share on other sites More sharing options...
marv Posted May 15, 2014 Author Share Posted May 15, 2014 Here is a pic of my new plugs after. 80miles Quote Link to comment Share on other sites More sharing options...
Krzys Posted May 15, 2014 Share Posted May 15, 2014 Looks predominately bad on one cylinder and not as bad on the other. Have you had a chance to get the exhaust mani off to check that side as suggested further up? Quote Link to comment Share on other sites More sharing options...
marv Posted May 15, 2014 Author Share Posted May 15, 2014 Looks predominately bad on one cylinder and not as bad on the other.Have you had a chance to get the exhaust mani off to check that side as suggested further up?Yep no4 is the worse and it was fine before. Not had a chance,working till 5 the day and got my final exam tomorrow so not sure if il get it checked tonight. Quote Link to comment Share on other sites More sharing options...
Krzys Posted May 15, 2014 Share Posted May 15, 2014 Ah right, Good luck with your exam! Concentrate on that first dude, the car will wait! Quote Link to comment Share on other sites More sharing options...
marv Posted May 15, 2014 Author Share Posted May 15, 2014 Ok had a quick 5 mins when I got home so whipped the exhaust manifold off. Couldn't see any oil residue like before.Il remove inlet next so see if there's any signs of oil there. If there's not then is it the rings?Cheers Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted May 15, 2014 Share Posted May 15, 2014 Definitely looks a lot worse on no.4. like you say and looks good on the exhaust side, hopefully you'll know more when you get the inlet off. It does look like the heads got to come off again though what ever. I guess you'll know for sure then if it's rings, I do hope not but wouldn't the signs have been there before? Quote Link to comment Share on other sites More sharing options...
Grant Posted May 15, 2014 Share Posted May 15, 2014 Definitely looks a lot worse on no.4. like you say and looks good on the exhaust side, hopefully you'll know more when you get the inlet off. It does look like the heads got to come off again though what ever. I guess you'll know for sure then if it's rings, I do hope not but wouldn't the signs have been there before?I thought it was pressure tested before it came off??Which should rule out rings. Peculiar though why there's nothing showing visibly with the exhaust mani off though. Quote Link to comment Share on other sites More sharing options...
